clunk noise when suspension compresses?
Old Sep 5, 2013 | 01:24 PM
Sturmcrow's Avatar
Was it "clunk"ing before the wheel bearing refresh?
Does the front end feel loose at all when you hit bumps? Mine had been making a little noise and feeling a bit loose for awhile, but I did not realize that it might be the LBJ's until Mudhippy's contribution to the thread I linked. All of a sudden I was afraid to drive the stupid thing, fearing that a balljoint might come apart on me (had that happen once, and that was more than enough for me).
I am not sure if this is the prescribed way to check them, but I just inserted a long prybar between the lower control arm and the steering knuckle to test the LBJ. I lifted up, the steering knuckle went up in relation to the control arm, and I placed an order for some replacements.
Old Sep 5, 2013 | 02:08 PM
Steve92yota's Avatar
Yes it did. That was the reason I figured I try them. Ill try to check when I get home tonight.
Old Sep 5, 2013 | 04:27 PM
Kiroshu's Avatar
Check Torsion bar mounting location component(s) in the rear.
Old Sep 5, 2013 | 07:35 PM
Ocell's Avatar
I've had the exact same symptoms in my truck for a while. I've been thinking it's my control arm bushings. The edges are cracked badly so I'm sure they're shot. I haven't replaced lower ball joints, but I've replaced one upper and I'm about to replace the other upper. So, I can't rule out lower ball joints for you, but mine seem to be fine.
nvdesertrunner
May 11, 2020 08:18 PM
JNapolitano
Nov 14, 2019 07:46 PM
norcal98
Aug 10, 2015 06:20 AM
gillesdetrail
Aug 3, 2015 04:43 PM
ripp96
Jul 25, 2015 02:32 PM
