Clinometer found today
Old May 12, 2010 | 04:49 PM
SwampThing's Avatar
Depends Camo. It only registers up to 30deg, and depending on your suspension setup, center of gravity, speed and momentum, wheel location and situation, you might roll way before 30deg or way beyond 30deg.
But they're nice to have regardless.
Old May 12, 2010 | 04:52 PM
camo31_10.50's Avatar
that helps, i'll just stick to my original plan of, when my butthole stats to pucker up, i better not go any further or i'll tip LMAO
Old May 12, 2010 | 05:08 PM
SwampThing's Avatar
Yeah, the pucker-factor usually will usually save you, unless you're like me and your balls are bigger than your sense of self-preservation...
Old May 13, 2010 | 04:32 AM
space-junk's Avatar
ahahahahaha...
Old May 13, 2010 | 05:00 AM
  #25
rattlewagon's Avatar
Camo- it only works up to 30 degreese, and you can have it more than that. Ive maxed out mine in my runner. Both on the front and the side (scary, but didnt roll) I think 4crawler took his apart and made it be able to read more. Also you have to be stoped for it to read properly. Its pretty much just a neat-o novelty thing.
Edit: 4crawlers link
http://www.4crawler.com/4x4/CheapTri...inometer.shtml
Old May 13, 2010 | 06:51 AM
  #26
Philbert's Avatar
they're fun to watch on freeway exit ramps (cloverleafs)....I've maxed mine out before too - it's pretty gaddgety, but I like gadgets!
Old May 13, 2010 | 04:32 PM
  #27
morena67's Avatar
....A gadget in a 23 year old truck, hmmmm
Old May 13, 2010 | 04:42 PM
  #28
PismoJoe's Avatar
Originally Posted by camo31"10.50"
is this thing just used to tell you at what angle you are...or does it actually show you when you're about to tip the frick over?
if it is actually really accurate as to when my fat arse 4runner is about to tip over, i'd prolly by the one on craigslist forsale
Well mainly, it looks BA to the maximum level haha
Yeah it tells you angles, and is actually pretty darn accurate. Also tells you the altitude if you have a later model one, and I can say driving up to the snow that thing was right on with the altitude signs. In my pic of my 4runner with a tire off the ground it was at 30 degress, but you know how crawlers do it, all you need is a rope tied to your car and someone can literally walk you through tight spots while your on the verge of tipping.
and it looks BA!!!!
Old May 13, 2010 | 07:58 PM
  #29
morena67's Avatar
Lights on...
:d...
Attached Thumbnails Clinometer found today-on1.jpg   Clinometer found today-on2.jpg
Old May 14, 2010 | 10:28 AM
  #30
tumor21's Avatar
Man, that's awesome. I want one in the worst way. GOOD FIND!
Old May 14, 2010 | 11:08 AM
  #31
morena67's Avatar
tHANX...
shisha1999
Aug 14, 2015 01:33 AM
irritech
Jul 27, 2015 05:15 PM
ddg71
Jul 24, 2015 01:24 PM
yourrealdad
Jul 21, 2015 11:13 AM
msane99
Jul 17, 2015 10:13 AM
