Cleaned intake and throttle body now poor gas mileage
Old Jun 4, 2009 | 09:39 PM
toyotarunner92's Avatar
Exclamation Cleaned intake and throttle body now poor gas mileage
just cleaned and dregreased intake plenum and throttle body and assembled everything correctly with new gaskets and everything. just replaced the fuel pulse dampener... ugh P.I.A.! but i got to clean everything out really well!!!
anyways i am getting terrible gas mileage and it smells like unburnt fuel in the exhaust... i have a leak somewhere but i can find it...
i have the toyota manuals and followed them step by step.
is there somthing i have to do to the throttle body? i already adjusted the idle cause it was a little high after the cleaning... i have gone 100 miles and i am already at half a tank... it used to be at least 125-140 miles on half. any suggestions would be great...
engine is 3vz btw...
thanks
Last edited by waskillywabbit; Jun 5, 2009 at 10:10 AM. Reason: Use titles specific to subject of post
Old Jun 4, 2009 | 10:06 PM
CRafferty's Avatar
maybe O2 sensor? IDK...
Old Jun 5, 2009 | 08:01 AM
the 02 sensor is pretty new... do you think if i lean out the VAFM that it will help any? i am going to try it today and see what happens... let me know if anyone thinks of anything else!
Old Jun 5, 2009 | 08:47 AM
Jay351's Avatar
Check the timing, and start checking for vac leaks
Old Jun 5, 2009 | 09:43 AM
checked all vac lines and everything seem to be plugged in correctly and no leaks... will continue looking though. thanks for your help
Old Jun 5, 2009 | 11:15 AM
DJ99's Avatar
My understanding is if you don't remove the TPS it can be harmed by the cleaning fluid.
I would not touch the VAFM, since it worked before you touched the throttle body.
Old Jun 5, 2009 | 03:10 PM
iamsuperbleeder's Avatar
TPS was going to be my guess...
if you dont remove it, yes it can be damaged
if you do remove it, you have to be certain you adjust it right when you reinstall it
Old Jun 5, 2009 | 03:18 PM
TNRabbit's Avatar
My FIRST guess would be you put a hose back on wrong....and are pulling gasoline directly into the intake.
Old Jun 6, 2009 | 09:12 PM
abecedarian's Avatar
pull the efi fuse or battery for a minute or two so the ECU will start with clean fuel trim maps... or wait for 10-20 full start/stop/re-start cycles for the ECU to adjust the trim maps to the new setup. definitely check the timing and idle speed as well as the TPS adjustment / performance.
However it could be the cleaning has fouled the O2 sensor and it is reading abnormally.
Old Jun 6, 2009 | 10:05 PM
Bako88's Avatar
If you worked on the intake it could also be that the cold start injector has stuck open and is running gas in when it shouldn't be. But I'd take ABE's advice first.
smthwsn357
May 1, 2024 07:28 AM
Jun 1, 2021 01:51 PM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
raiderhawks00
Jul 8, 2015 06:23 PM
