Clarification on Oil pan removal...
Old Aug 17, 2010 | 11:48 AM
dhall50's Avatar
Before I get yelled at: I DID SEARCH. Some said you can remove the pan by only jacking the motor and trans up and some said you cant. Is there a secret trick like you have to remove the oil pickup before the pan will slide out all the way? This is an 86 22r so any input would be great.
Old Aug 17, 2010 | 11:50 AM
blake.nemitz's Avatar
that or drop you diff, i would jack it up its easier but without a body lift you might not have enough room
Old Aug 17, 2010 | 04:01 PM
karuso86pu's Avatar
2wd w/o jacking it up:
Remove the crossmember.
Disconnect the idler arm & pull the steerink link down as far as it will go.
Unbolt the stabilizer bar mounts & pull that down as far as it will go.
It's close, but the oil pan can be removed/installed.
Old Aug 17, 2010 | 04:27 PM
92 TOY's Avatar
several step process on my build (22re 4wd) can find it all in my SIG....pick thread B
EDIT...to be more help to you, start with post #29 of THREAD B
Old Aug 17, 2010 | 05:10 PM
TOYOTA 1's Avatar
i remove the front 3rd.. its quick, easy, and gives you plenty of room.
Old Aug 18, 2010 | 07:14 AM
Stuwy123's Avatar
Remove the front diff completely. I tried with just dropping it down. Doesn't work.
With the front diff out, you can see all the bolts holding the pan on.
Remove the diff and you can take the oil pan out easily. You can slide the pan back a bit and down. The pickup tube is not attached to the pan, I think. Haha. Sorry it was really late last time I took my pan off. Three or four bolts hold the pickup tube to the block.
Make sure you scrape the block and pan good before re-installing it.
Old Aug 18, 2010 | 08:19 AM
camo31_10.50's Avatar
i feel sorry for you guys.
this should be a GOOD reason to get a 4"-6" bracket lift!!! lol i can drop the pan on my 3vz without doin anything EXCEPT disconnecting some of my steering.
Old Aug 18, 2010 | 01:44 PM
dhall50's Avatar
Ok ladies and gents. On an 1986 4wd 22r you can remove the pan by jacking up the motor. U have to unbolt a steering bar and wiggle it around but it will come out.
Old Aug 18, 2010 | 02:06 PM
peow130's Avatar
I just took the 3 bolts off the front diff and let it aim down, then unbolted it and manuevered it out of the way.
I also removed the steering dampener thingy.
Didnt have to jack up the engine.
Old Aug 18, 2010 | 02:14 PM
modlite's Avatar
On mine, I put the jack under the bell housing and jacked up the motor just to get the jack snug, then took the front motor mounts off, jacked up the motor, removed the front steering stabilizer, then removed the oil pan.
You have to get the oil pan down just a little bit, then take the pick up tube off with it still in there then you can maneuver it out.
I changed the rob bearings in my engine this way with the front differential still in.
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
irritech
Jul 27, 2015 05:15 PM
toofly1999
Jul 25, 2015 07:09 PM
ryerye13
Jul 14, 2015 08:27 AM
