Check engine light comes on after being deleted, before even starting
Old 12-08-2010, 12:59 PM
rusty87's Avatar
Left negative battery cable off for almost 24 hours with EFI fuse pulled and as soon as I put the key in and turned key to ON position (not cranking) the check engine light came on.
I thought OBD1 should not store code/s until it runs for a while. Is this correct?
Old 12-08-2010, 01:02 PM
NicCantDecide's Avatar
I'm pretty sure the CEL, Battery, and Oil Pressure lights are always on when you have the key turned to On with the engine off.
Old 12-08-2010, 01:13 PM
toyota4x4907's Avatar
Uhm thats normal....
Old 12-08-2010, 01:37 PM
diablo's Avatar
yes that is what mine does
Old 12-08-2010, 01:43 PM
Bojangles's Avatar
Thats normal...
Also there is no need to have the battery cable and EFI fuse out for that long.
30-45 seconds tops and it deletes all codes.
is your best friend when it comes to questions like these.
Old 12-08-2010, 02:10 PM
rusty87's Avatar
ok. ok. stupid brain fart. but I just started it and check engine light stays on.
I had an o2 code and just replaced with new NGK/NTK o2 and it still running like crap.
Old 12-08-2010, 02:24 PM
Bojangles's Avatar
Oxygen sensor code: #5
Knock sensor code: #51 #52
Im thinking you may POSSIBLY be reading the code wrong...
But im not a hundred percent sure...
http://www.troublecodes.net/Toyota/
rbravo1
06-29-2015 01:34 PM
Alex Bessinger
06-28-2015 10:05 AM
94hiluxZE
06-22-2015 10:42 AM
Mutinebullfrog
06-18-2015 01:36 PM
Dr. Evil
06-07-2002 09:19 AM
Quick Reply: Check engine light comes on after being deleted, before even starting
