cheap mods for 89 22re more HP
Old Jun 13, 2006 | 05:19 PM
yotamaster1988's Avatar
Exclamation cheap mods for 89 22re more HP
does any one know or wish to share any info on how squzze any extra horespower out of my 89 toy pickup shortbed deluxe with the 22re
i already got the k&n filter element and brand new fuel injector
any other mods that aint exstensive
Old Jun 13, 2006 | 05:31 PM
Elton's Avatar
on my 22re 164k on the motor i had a had a highflow cat 2.25'' pipe to a flowmaster delta 40 it had more power ...it was fine then i got a Lce header and man it made a difference
Old Jun 13, 2006 | 05:41 PM
Elton's Avatar
also adding a cam will help
Old Jun 13, 2006 | 05:53 PM
oly884's Avatar
Guest
what will work the best is a search. https://www.yotatech.com/search.php
Old Jun 13, 2006 | 05:55 PM
oly884's Avatar
Guest
and, if you notice at the bottom of this page, you'll see similar threads.
Old Jun 13, 2006 | 07:37 PM
trythis's Avatar
Try this write up: http://www.4x4wire.com/forums/showfl...&o=365&fpart=1
Old Jun 13, 2006 | 08:05 PM
Jonnym's Avatar
electric fan mod... helps the truck sound less like an aircraft...
Old Jun 13, 2006 | 10:21 PM
YotaND's Avatar
I really like the Aircraft sound. I remember the day I finaly got the stupid loud exhaust leak fixed on my 92 pickup with the 22re, man I miss that tuck. I heard the fan for the first time and thaught it was awsome. Mmaybe I just associate that sound with a good running truck.
Old Jun 15, 2006 | 10:00 PM
Spanky's Avatar
aircraft sound huh??
Old Jun 17, 2006 | 04:53 PM
Jonnym's Avatar
yep an aircraft, but even better than adding power was the 6dB drop in noise @ 30mph, 3krpm - if anyone is intrested, i took a bunch of data points for noise before and after the fan mod, also did a full dynamatt install. but really, the fan sucks maybe 5-7 hp at 3000rpm- it was a noticable difference...
also - synthetic fluids was a good addition.
Old Jul 2, 2010 | 04:27 AM
RBX's Avatar
RBX
Originally Posted by YotaND
snip...
then just install the Mercury Villager/Nissan Quest fan, when that sucker kicks into the hi-speed....its plenty loud. Just knowing that the fan is not driven off the crank is worth at least 11ty billion HP gain...haha.
Old Jul 2, 2010 | 05:12 AM
thralldad's Avatar
Cool stickers!
Old Oct 13, 2010 | 05:26 AM
1sennafan's Avatar
My header helped the most!
Old Oct 13, 2010 | 05:51 AM
blake.nemitz's Avatar
header, intake, maybe afm mod and egr delete, advance the timing and run better gas
Old Oct 16, 2010 | 09:21 PM
MuddfreaksOffroad's Avatar
my dad has a mild stage 2 rv cam, a 2.25in exhaust high flow cat and flowmaster, has the k&n air filter kit and larger injectors and the truck was tuned. So other then them u can bore it, and build up the block for compression, ( stroker ) and dome pistons. altho not many people put that much into a 22re most do a swap. but my dad is running 35x14.50 boggers with 4.88 and runs 70mph at 3 grand on the high way, he has plenty of power for his truck, not no zippy imma race this honda here power but it has enough for waht it is.
Old Oct 16, 2010 | 09:39 PM
Randyman...'s Avatar
I initially did a Downey Cam, 4-to-1 Headers, K&N filter, and MSD and got a descent bump in performance. I cracked a valve (running too lean) and decided to spring for the LC Engineering EFI Head/Cam, plus the Tri-Y headers and high-flow injectors and the powerband was SO much better. Smoother torque curve and obviously more overall power! Needless to say the head alone was $1K - so not exactly a cheap upgrade - but aside from a complete stroked LC Racing Motor - it was one of the most peppy naturally aspirated 22RE's I had personally seen. Too bad the block is warped and it's been sitting parked for almost a decade! Time for a V6/V8 motor swap
Nudging the MAF's spring a few ticks looser will richen you up somewhat with the tradeoff of less MPG. Advancing the timing a hair can help. Both free mods - but just beware of issues if you take either too far...
montanatruck
Feb 26, 2017 07:07 AM
bobpat
Aug 1, 2015 09:25 PM
Massmayhem247
Jul 18, 2015 05:46 AM
icentropy
Jul 11, 2015 07:21 AM
Nickdigg
Jul 7, 2015 06:04 AM
