CEL!....its not the O2 sensor
Old Feb 22, 2008 | 12:27 PM
RedRider's Avatar
anybody?
Old Feb 23, 2008 | 01:55 PM
mudtoy1986's Avatar
hmmm well i would have guessed that it was an o2 senser try removingthe ecu or maybe u could check ure injectors idle air control maybe a vacume line make shure u have no leaks in ure exaust
Old Feb 23, 2008 | 01:59 PM
toytech76's Avatar
its probably a code 52 which I believe is your knock sensor. That would make sense if the light goes out when you coast since your eng isnt under a load
Old Feb 23, 2008 | 02:00 PM
toytech76's Avatar
dont guess at whats wrong. Throwing parts at something without knowing what it is for sure just costs you time and money
Old Mar 18, 2008 | 04:10 PM
  #25
RedRider's Avatar
oh, it also gets stuck on high idle when ever i go to neutral. I can punch it and it drops back down. I dont think it is physically sticking because when I put it in gear and let off the clutch just a little (w/o touching the accelerator) then put it back in neutral it goes back to a higher idle. Wait, I think that happened before the CEL came on... dunno, could be a symptom
Old Mar 18, 2008 | 04:19 PM
  #26
nate V's Avatar
get a chiltons or haynes repair manual for your rig thay have all the codes listed in there for future use
Sam hain
19
Sep 30, 2015 08:25 AM
charlie_fong
Sep 27, 2015 10:06 PM
aafrench7
Aug 30, 2015 06:38 AM
nonstop
Jul 24, 2015 06:29 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
