can't find my flasher.
Old Feb 18, 2008 | 02:24 PM
89trknwby's Avatar
i did a search and found nothing. PLEASE HELP!! i can't find my flasher.it's a 89 pickup 4x4. my front left trun signal doesn't work. replaced the bulb. the back left works, then when i press on the brakes the left turn signal light in my cluster will light up . the right side works fine . any ideas? also , my taillights are off of an older truck. do the 89's taillights have a hraness directly on the back of them? i tried to look at the wiring but it's very windy and cold. PLEASE HELP
Old Feb 18, 2008 | 03:03 PM
eric-the-red's Avatar
Should be plugged into the back of the fuse box under the dash. But if any of the turn signals are working then the flasher is OK. If you've got a trailer wiring harness check that first, they're a common place to get crossed wires between the brake lights and turn signals. Otherwise it sounds like the problem is in the tail light assembly.
polo451
13
Nov 20, 2016 07:49 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
HookahRoo
Jul 20, 2015 07:06 PM
scottyg486
Jul 19, 2015 05:34 PM
sojourner567
Jul 16, 2015 08:52 PM
