Cant find ISR mod parts...
#64
PVC has a thinner wall which may contribute to less heat retained than ABS. I personally found that ABS is very differant in size due to that thickness. I think I a,m going to try and fab another one out of PVC or maybe 2 1/2" hose. and see if I notice a diff. btwn that and the exh. pipe.
#66
I redid mine with 3" schedule 80, 45* w bell end. (local home depot in the plumbing section) I had to cut a very minimal bit of the edge of the ends to make it fit great. I saw it on another thread here. It works great! plus all I had to do was drill the fitting holes about 1/16 smaller than the fitting and the tap themselves right in.
I got the biggest performance increase(by feel anyway) new filter, removed mass air sensor and cleaned it with the appropriate spray. I think if you have done the ISR mod your MAFS gets dirtier quicker. I noticed even better throttle response.
#67
home depot in my area didnt have it so i got some random bent 3 inch pipe cut like a 8 inch section then stuck plumbing rubber clamps on each end. the throttle body end i left the stock pipe on and stuck the clamp on. didnt want to spend another 9 bucks on the fittings. later on i will bend some pvc and get rid of that black intake hose. its a pain in the ass to check the oil level have to pull the dipstick out at an angle
icentropy
Jul 11, 2015 07:21 AM
tpd143
Jul 7, 2015 09:06 AM
