can i fit 35"s
Old Feb 25, 2008 | 03:40 PM
91pearlyota's Avatar
can i fit 35"s
hey guys i've got a 91 toyota pickup 4wd with 31's and im going to put a 3" BL, a 1.5" BJ spacer and crank the T bars, and 3" blocks for the rear and i'm wanting to know if i can fit 35"s ok without any problems
Old Feb 25, 2008 | 03:43 PM
TOYOTA 1's Avatar
look at my avatar lol 35x10.50x15 boggers with only 3" body
Old Feb 25, 2008 | 03:45 PM
Azusacanyonbogger's Avatar
depends on your wheels offset. i'd say your lower valance will probably have to be taken off. either that or the tire will take it off for you!.
i'm running 35's with 3" body and 4" susp. no rubbing whatsoever. i have no lower valance. and pre-runner fenders though. also i bashed the parts in the fenderwell flat. the small ridge in the fenderwell needs to be flattened.
Old Feb 25, 2008 | 03:53 PM
TOYOTA 1's Avatar
yes i rubed a little in the front but not that bad becouse IFS doesnt realy flex that good!
unless u have a totalchaos lift!
Old Feb 25, 2008 | 08:31 PM
fillsrunner4's Avatar
Nothin a good old cant fix
It takes less than you think to really be able to clear 35's with minimal rub just depends how far you want to go with it
Old Feb 26, 2008 | 04:13 AM
dirtoyboy's Avatar
will it fit?
sure...
will it ride like a log truck?
probably....
what gearing are you running with the 35's?
Old Feb 26, 2008 | 04:24 AM
its has 4.56 right now but im going to be putting 5.29's in it along with an auto locker of some sort
Old Feb 26, 2008 | 05:59 AM
AxleIke's Avatar
It'll be fine.
However, keep in mind that the BJ spacers and tbar crank will NOT help you except on the street, unless you shim your bumpstops WAY down. Otherwise you will still flex right back to where you are now.
The 3" BL will help big time. Just put the tires on, and cut the fender to fit. No problems.
Old Feb 26, 2008 | 08:10 PM
bigarms23's Avatar
sounds fine
Old Feb 27, 2008 | 04:47 AM
gt0987's Avatar
You're going to install BJ spacers and then crank the T-bars for 3" of front lift? Your CV angles are going to be pretty maxxed out.
Old Feb 27, 2008 | 05:52 AM
AxleIke's Avatar
And the tbar/BJ spacer lift won't help him clear the tires.
87SR5justin
Sep 29, 2015 02:50 PM
4runnerFireman
Sep 29, 2015 06:24 AM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
mtrdrms
Sep 26, 2015 07:12 AM
anniesball
Sep 5, 2015 08:45 AM
