can i fit 35"s
can i fit 35"s
hey guys i've got a 91 toyota pickup 4wd with 31's and im going to put a 3" BL, a 1.5" BJ spacer and crank the T bars, and 3" blocks for the rear and i'm wanting to know if i can fit 35"s ok without any problems
i'm running 35's with 3" body and 4" susp. no rubbing whatsoever. i have no lower valance. and pre-runner fenders though. also i bashed the parts in the fenderwell flat. the small ridge in the fenderwell needs to be flattened.
It'll be fine.
However, keep in mind that the BJ spacers and tbar crank will NOT help you except on the street, unless you shim your bumpstops WAY down. Otherwise you will still flex right back to where you are now.
The 3" BL will help big time. Just put the tires on, and cut the fender to fit. No problems.
87SR5justin
Sep 29, 2015 02:50 PM
4runnerFireman
Sep 29, 2015 06:24 AM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
anniesball
Sep 5, 2015 08:45 AM
cant fix
