Camshaft bolt removal for a timing chain install
Old 03-22-2012, 06:07 PM
2012MongolRally's Avatar
Ok.... even though I have seen many threads such as this
https://www.yotatech.com/forums/f2/t...s-85-22r-1154/
I think I figured out that M8 and M10 are measure of the threads of the bolt not the hex head of the bolt. Is this correct? So....
-M12 hex head = 8mm bolts = 9ft-lb
-M14 hex head = 10 mm bolts = 29 ft-lb
Old 03-22-2012, 07:28 PM
4Voigt's's Avatar
tensioner is good put it together.
Old 03-24-2012, 04:07 AM
Bassmastry101's Avatar
As long as you don't feel anything out of the ordinary when you turn it then it will be fine. Rotate the crank one full turn (cam will do two turns) and set it back to tdc at the crank (key will be at 12 o'clock) and if your cam gear lines up the way it was then your all set.
About the grooves in the main pulley..I reused my old one since it seemed fine. I would follow the previous thread you posted to see if it is sealing properly. Put it together and let it ride!
Old 03-24-2012, 04:25 AM
irab88's Avatar
*the cam does 1/2 turn for every turn of the crankshaft. rotating the crankshaft 2 turns will move the camshaft 1 turn
Old 03-24-2012, 04:49 AM
  #25
Oh hah! too early, thanks for catching that. Every one turn of the crank will turn the cam one half turn.
fasterspider
10-06-2015 10:24 AM
Ichneumon
09-27-2015 04:21 PM
hexrain
06-27-2015 06:17 AM
paxanders
06-21-2015 06:29 AM
Quick Reply: Camshaft bolt removal for a timing chain install
