Cable driven speedometer issues
Ok so I’m new here. I’ve been fallowing some discussions on here for a while but my question has yet to be answered. My speedometer cable quit working I tried replacing the gauge as well as the cable still having the same issue also my tach isn’t working. I’m driving a 91 with a 22RE and a 5 speed 2wd. Please help
Edit
I did get a new cluster out of an SR5 because I wanted more than just idiot lights I followed this thread with installing it
https://www.yotatech.com/forums/f116...06/index6.html
Does the speedometer work at all?
With the speedometer cable, the speedometer and tachometer are independent of each other.
Did you confirm that you have a wire in the wire harness for the tachometer? If there is no wire for the ignition signal, the tachometer will not work.
matt92yota
Oct 8, 2011 11:37 PM
vegascoug
Feb 11, 2006 04:19 PM
