A/C compressor location?
Old Jun 30, 2013 | 06:44 PM
Neil McCon's Avatar
I have a 89 toyota pickup 4 wheel drive with the 3.0. When i bought it the guy told me the ac just needed recharged with freon so i have thought sense it was summer time i should get that done but when i tried to find the compressor which is where the recharge valve should be i cant find it? Inside the cab it has the added ac button which lights up when clicked but no difference in the temperature. Is it possible that the compressor was removed and never replace? Or where is the compressor actually located at? i could really appreciate the help, thanks!
Old Jun 30, 2013 | 06:53 PM
YotaWoRx's Avatar
Should be below the power steering pump
Old Jun 30, 2013 | 07:04 PM
Neil McCon's Avatar
Okay I think i found it but where exactly is the recharge valve?
Old Jun 30, 2013 | 07:20 PM
YotaWoRx's Avatar
On the low pressure line. Close to the firewall
Old Jun 30, 2013 | 08:29 PM
Neil McCon's Avatar
How do I know the difference between which is high and which is low? An what type of refrigerant do i need?
Old Jul 1, 2013 | 08:32 AM
YotaWoRx's Avatar
The line that's closest to the hood surface is the low pressure line. Some valves have a blue cap indicating low side. As far as the type of refrigerant, it depends on whether the system has been retrofitted to r134a. U can tell if it has either by a sticker under the hood somewhere saying so, or looking at the Schrader valves. When retrofitted, a bigger valve is screwed onto the existing valve so to speak. My advice would be to have the system checked by an a/c shop for leaks. There is a reason why the system is low. Most likely a leak....
mussy01
Dec 13, 2016 08:20 PM
klavender1
Aug 15, 2015 01:51 PM
stock87yota
Jul 31, 2015 10:08 AM
skoti89
Jul 8, 2015 12:05 AM
bryan34w
Jul 6, 2015 05:53 PM
