A/C actuator/diaphragm adjuster vs A/C amplifier adjuster
Old Jul 19, 2019 | 09:05 AM
Paul22RE's Avatar
5 Year Member
Do they both do the same thing allowing adjustment of engine idle RPM when A/C is on? Is it just that the actuator/diaphragm uses vacuum and amplifier uses electronics to make the RPM change at idle?
Edit: I just read in another forum that the amplifier sets what RPM allows the compressor to kick on/off and does nothing with the idle. I'm confused since the amplifier does seem to change engine RPM when turning knob &then cycling the AC switch.
Old Jul 21, 2019 | 04:25 PM
scope103's Avatar
WHEN the A/C turns on, the idle is raised by the A/C idle up. To what? On the 22re only, you can adjust the increased idle at the VSV (not adjustable on the 3VZE).
When the engine rpm gets "too low," the A/C Amplifier shuts off the compressor. How much is too low? It's set on the amplifier.
4Xtruck
Apr 27, 2017 02:08 PM
dj-86yota
May 19, 2012 08:29 PM
YodaPala
14
Nov 6, 2008 02:57 PM
89934runr
Jun 26, 2006 07:08 PM
Piett
Aug 23, 2005 08:33 AM
