Burped cooling system for 42 minutes still gurglin! $%^&*
Old 04-04-2006, 09:30 AM
FilthyRich's Avatar
When I noticed the temp gauge rise, I immediately turned the heat on high. i didn't want to overheat anymore.
But assuming in my 88, I don't have the bypass, then how long does it take for the temp. to drop?
from now one, Brian, you are getting forwarded my questions....
Old 04-04-2006, 10:00 AM
gohawks's Avatar
Straight from 4crawler's site:
Thermostat:
After everybody looked at me like I was crazy for saying that it ran hotter with the heat on, I went to the dealership and bought t-stat part # 90916-03070. This did the trick. What happens on the 22R and 22RE engine, when the coolant goes through the heater core it gets cooled off enough that when it gets dumped back in on top of the t-stat it shuts it. Therefore the temperature in the engine continues to go up. The t-stat that I have mentioned has two valves in it, one at the regular temp. and one smaller on at a cooler temp. If the cool water shuts the big one, the smaller one stays open. All this happens because of the lack of a by-pass hose, which on other systems, keeps hot coolant running on the t-stat. On the subject of the overheating thread, an engine can run hotter with no t-stat. But it would probably be a system configured differently than the 22re. Mine runs cold when the t-stat is removed.
Another advantage of the 2-stage thermostat is that the thermal "inertia" of a thermostat is greatly affected by the mass of the temperature sensing element (a.k.a. slug) on the thermostat. The normal single-stage t-stat has one big valve with a large spring and a large slug to force the spring open. The 2-stage t-stat, on the other hand, has a tiny valve and a medium sized valve, with tiny and medium sized springs and slugs. This lets the smaller t-stat valve react very fast to engine temperature changes and the medium sized valve, although a bit slower, still operates faster that the one large valve.
A lower-cost version of this can be done by drilling one or more small holes around the edge of the single state t-stat to allow some coolant to flow all the time. This functions like the normal bypass hose on other engine designs.
On the subject of thermostats (or turd-mo-stats for Toy4x4 old-timers:-), I once tried one of those "fail safe" thermostats. A normal t-stat has a spring that holds the valve closed and the slug forces the valve open in response to coolant temperature. The slug has a sealed chamber with a temperature sensitive medium in it that expands when heated. The typical t-stat failure mode is that the chamber leaks or swells, preventing the t-stat from opening. The fail safe thermostat has a catch that is engaged when the t-stat valve opens fully and then the valve is held open. I guess the idea is that if the engine ever does begin to overheat, the t-stat locks open and prevents further damage. Well anyway, I had installed one once, and it worked fine. One day, I lost the silicone oil out of my fan clutch (didn't notice this until later when I popped the hood and saw the results) on a hot (100F) day. I recall seeing a slight temp rise once, but nothing too bad. Some weeks later, on a cool night, I turned on the heater and got almost no heat. This is when I popped the hood, saw the oil sprayed all over and put two and two together. Pulled the t-stat out and sure enough, it was latched open, so I guess it did its job. However, I now had to replace the t-stat, since once it locks open, it can't be reused. But I guess this also shows the engine runs cooler with at least a wide open t-stat in it.
90916-03070 09916-03078 vs. 90916-03070
Old 04-04-2006, 10:03 AM
FilthyRich's Avatar
I just read all of this--on Roger's site. he only mentins 83-85 22re motors.
The part number he uses is 90916-03070, which is a 2 stage t-stat.
Does anyone know, without obviously pulling the existing t-stat, if the 88 22re came with a bypass valve or not.
i don't mind getting a new t-stat and flushing and refilling the radiator, but I am just trying to figure out this random. intermittent overheating....
JaredL
03-28-2016 09:08 PM
mbomberz1
08-08-2015 06:57 AM
TJWilly
07-31-2015 02:05 PM
Logz808
07-26-2015 07:09 AM
kyletbert
07-17-2015 11:39 AM
Quick Reply: Burped cooling system for 42 minutes still gurglin! $%^&*
