Burning Oil but no leak? And rough engine... vaccum issue?
Old Jun 28, 2010 | 08:26 AM
regnar11b's Avatar
I have had my 4runner for over a decade and it runs great. Its a 1990 3vze 4wd 4runner with 252,000 miles, I have always done all of my own work and maintenance on it so that I know its done right; plus I have access to a full shop for any issues. During the last 3 months my fuel damper on the fuel rail went out under the plenum. During the replacement the plastic nipples on the BVSV (bi-metallic service valve) broke that connect to the charcoal canister. I replaced the BVSV and everything is back to normal. There is no more gas smell from the leaky fuel damper however every once in a while I smell oil burning in my cab, if I switch the vent to internal you can't smell it. When I park after driving it you can sometimes smell it outside the vehicle next to the driver side wheel well but not on the passenger side. I have checked the block and under the engine along with everywhere around the engine compartment and can't find any leaks, but in one 2,500 mile cycle I burned 1 quart of oil. I also taped and numbered all of the hoses when I pulled the plenum and was sure I put them back correctly but I could be wrong.
-Could the BVSV be bad or the charcoal canister gone out?
I haven't used a mirror to look under the back of the plenum yet. But also noticed now if my truck is running and I pull the dip stick it starts idling very hard and when I put the dip stick back in it goes away.
-Could one of my vacuum hoses be plugged in wrong? I only have my Chilton that doesn't have any vacuum diagrams. Can someone post a link for the correct vacuum diagrams I'm having a tough time finding them.
Old Jun 28, 2010 | 08:32 AM
85gijunk4x4's Avatar
the rough engine is most likely a vacuum leak.
now about the oil, is there any blue smoke coming out from the exaust? if there is it could be a bad valve cover gasket, or valve guide seals etc.
Old Jun 28, 2010 | 08:41 AM
regnar11b's Avatar
When I was changing the hoses two lines were old tough and brittle so I changed the lines out with new ones. But I will check the lines again, is there any easy way to find a leak if you cant hear a hissing?
There is no colored smoke coming from my exhaust. That can also be a worn piston ring right?
I was also told to check my PCV valve because they can go bad. Would that effect the engine burning the oil vapors?
Old Jun 28, 2010 | 12:38 PM
bugs1961's Avatar
This thread has good info on the hoses on the passenger side of the plenum.
https://www.yotatech.com/forums/f116...e-help-209069/
Old May 16, 2012 | 09:22 AM
FNV's Avatar
FNV
Hey guys, I found this thread by searching for "dip stick idling".
I'm basically having the reverse problem that regnar11b described: when I pull the dipstick out, the engine sinks down to a calmer, quieter idle, and as soon as I put it back in, it revs up again to an unhealthy level.
The check engine light just came on last night, and I haven't run a diagnostic yet. I just replaced the TPS and the cold start injector so I'm wondering "WHAT NOW?"
-Sage
bigjstang
Jun 2, 2025 03:56 PM
Colington
Mar 8, 2020 09:51 AM
nick b
Jul 11, 2015 04:38 AM
87blyota
Jul 10, 2015 04:31 AM
HRDC0R19
Jul 5, 2015 06:43 PM
