burned up 85 pu with sold axle what do you think
Old Oct 30, 2007 | 07:03 PM
fillsrunner4's Avatar
Originally Posted by DeathCougar
YOu'd be suprised the number of parts that are salvagable from total burn vehicles.
thats true and yes you could make money off it easy...
But, would you run that axel?
Old Oct 30, 2007 | 07:06 PM
thook's Avatar
Not only that, a welder burns very frickin' hot...hotter than that fire was. After all, the body did not melt....which is what a welder does. Melt.
Old Oct 30, 2007 | 07:08 PM
alright then run that axle i dont care its your choice. all im saying is i wouldnt
Old Oct 30, 2007 | 07:16 PM
thook's Avatar
He's not even replied yet, guy. Translation....no decision he's made. Thing is, it is still being suggested he get it checked. If it checks fine, what's the problem?
Old Oct 30, 2007 | 07:25 PM
  #25
Tacoma750's Avatar
THOOK...you can't compare fire to welding...Sure welding is SUPER hot,but when welding sheet metal or on an axle you do spot welds or stich welds. Its not a constant heat. You do a little hear, go to the other side and do a little...go back to the other side, so on and so forth. This keeps the metal from warping, buy only heating a small section and letting it cool before you weld near that section again. Welding/fire are diffeant all together
Old Oct 30, 2007 | 07:34 PM
  #26
paxil4x4's Avatar
Drama Queen/Banned
There is a huge difference between welding and fire. Welding the heat is affecting the part directly, a fire well a lot of the heat is rising. Last time I looked the nature of fire is to burn up and not down
Old Oct 30, 2007 | 07:40 PM
  #27
SoCalWheeler71's Avatar
I had a BMX frame (a Standard STA for those that know BMX; thin wall 4130 chromoly- very heat sensitive) that was in the back seat of my buddies VW bug when it burned to the ground. I went with him to the tow yard to see what was left; lo and behold it was still sitting there on what was left of the backseat springs, all the paint was burned off. The bug looked much worse than that truck, the magnesium block went up and melted the whole back end of the car. I had the frame sandblasted and powdercoated, then sold it to friend who rode it for years afterwards. No cracks, not a single problem.
Heat travels up and the axle was under the truck, I really doubt there's anything wrong with it other than the soft parts needing replacement. What warps housings when being welded is the uneven, intense heat. I would run it.
edit- I just looked at the pics again- the tires are still there! And they look like they're still holding air. I don't think it got that hot.
Old Oct 30, 2007 | 07:53 PM
  #28
thook's Avatar
I understand how welding works. I watch it being done all the time. I also understand how hot something must be to change it's structure. That fire was not hot enough or intense enough. Probably why gasoline isn't used to weld.
Old Oct 30, 2007 | 08:15 PM
  #29
notanymore's Avatar
what is he wanting for it? if you can get it for cheap id take it for the axel then sell the rest for parts and scrap metal. And i dont think there are enough combustables to sustain a fire hot enough, long enough to warp the axels
Old Oct 31, 2007 | 03:58 PM
  #30
toy89yota's Avatar
i told him id give him $100 for the whole thing and just cut the front axle off and take the rest to the scrap yard
4x4-runner
Apr 18, 2017 09:08 PM
gieselman
Oct 12, 2015 01:34 PM
Sep 4, 2015 09:27 AM
terminator
Aug 10, 2015 09:15 AM
dfarr67
Jul 30, 2015 07:08 AM
