Bumps just dont feel right
Old Jul 25, 2013 | 05:07 PM
92Yoda's Avatar
Hey all i have this sound and feeling in the front of my 4runner most noticeable over speedbumps. Ive had it most of the time ive owned it and have replaced close to all of the front chassis parts but its still there,it sounds likethe wheel smacking on the hub but i checked the wheel and its tight, could my hub nut not be tight enough?
Old Jul 26, 2013 | 07:06 AM
Innocent Fool's Avatar
Did you check your sway bar bushings?
Old Jul 26, 2013 | 07:37 AM
Team420's Avatar
sway bar bushings as stated, maybe even lower control arm bushings,
Old Jul 26, 2013 | 08:44 PM
Sturmcrow's Avatar
Have you replaced your lower ball joints? I recently had a strange looseness in the front and that turned out to be the problem.
Old Jul 27, 2013 | 01:03 PM
92Yoda's Avatar
Time for new trans mounts?
Ive got the auto a340 and its shaken ever since i got it, ive done the third member, both ujoints in rear prop shaft and it still vibrates so i went and checked my trans mounts and they look pretty tired. is a bad trans mount only noticeable on decelleration? Or can it be noticed in accelertion as well? It only used to vibrate under decelleration but its started to vibrate almost all the time. Ive heard you are able to tell if engine mounts are bad by vibration on acceleration and by watching the engine shift while not moving is this correct? Here are a couple pics, first one is the trans mount taking all the weight and the second one is after i lifted the trans up an inch or two
Old Jul 27, 2013 | 01:07 PM
92Yoda's Avatar
Woopsies ment to make a mew thread, but to get back on topic lol yea those are good ideas i havent done those bushings yet, i was thinking of just taking my sway bar off, would anyone reccomend that? And i havent got the ball joints done yet but i actually ordered some yesterday so ill do that too. So uhh.. Would anybody beable to help my trans mount problem? Lol
punks_is_4x4
May 31, 2016 06:03 AM
Firefightersink15
Nov 23, 2015 10:32 PM
4Xtruck
16
Sep 24, 2015 09:38 AM
altydog
Sep 20, 2015 07:37 PM
punks_is_4x4
Sep 19, 2015 05:52 AM
