Broken wire..What to do about this?!?
Old Mar 4, 2023 | 07:52 AM
careercriminal's Avatar
Broken wire and not in a good place for repair. What to do...
Old Mar 4, 2023 | 07:58 AM
Discombobulated's Avatar
Well,
In a pinch I would solder it the best you can, liquid electrical tape and go with it, my OCD probably wouldn’t allow it for me, most of those have some way to get the other end out with a small screwdriver or tiny pick tool but can be a pain in the arse. It looks kinda green so the corrosion could go to the very end but I can’t see the other end, what plug is this??
Old Mar 4, 2023 | 08:10 AM
coopster's Avatar
From: exo-reality -wave if you see me; Front Range, CO
Yeah you can get that out. But imho you're best off to do so, make sure continuiity, fix, heat shrink, and put back in. Replacing the metal (pin or slot) onto said wire is a pain IFF you have them, and the special tool.
Old Mar 4, 2023 | 08:49 AM
Originally Posted by Discombobulated
Well,
The plug goes oxygen sensor on the exhaust.
Old Mar 4, 2023 | 09:12 AM
JoeS's Avatar
You can buy online new O2 plug connector with a pig tail for easy wire connections. I'd get a razor knife and cut off the insulation, solder the partially cut through wires for conductivity and strength, then liquid tape cover the exposed soldered wire.
Brownbeauty
7
Jan 21, 2017 02:24 AM
tardman91
Jun 1, 2011 09:12 AM
pattycakes77
9
May 3, 2008 07:17 PM
FredTJ
Aug 27, 2006 12:32 PM
jsrusse11
May 4, 2004 11:22 PM
