broken lug stud (plural), safe to drive?
Old Oct 20, 2009 | 06:54 AM
ayoung101's Avatar
ok, ok, i'll do it. next step: how? i've never replaced lugs before and i couldn't find anything about lugs in my repair manual. i'm assuming i just need to remove my rotor and punch the old ones out and replace with new? i've never changed rotors on a 4wd vehicle before. does the hub make it more complicated?
Old Oct 20, 2009 | 06:56 AM
Team420's Avatar
Originally Posted by turboboost
Also, those don't look like the correct nuts for the aluminum wheels.
x2!! They def are not the right ones, and should not be used with those wheels... the will eventually back them selves off, and prolly chew up those wheels.
Here...this should help ya figure it out.
http://www.ncttora.com/fsm/1990-1995...l/frontaxl.pdf
It is a lot easier than it looks.. and once you have done it, its 10x easier the next time.
Old Oct 20, 2009 | 07:10 AM
ayoung101's Avatar
wrong lug nuts? how can you have wrong lug nuts? apparently it's not just a nut? whatevs, all i know is those are the same lugs i've been using for 6 years without a problem.
oh, and whoever said they are $10 a piece, holy crap! my local auto parts store has them in stock for $1.50.
Old Oct 20, 2009 | 08:06 AM
ayoung101's Avatar
so i've been searching, and i've found conflicting posts on how to do this. some say you just remove the rotor like normal and then just leave the hub in place and pound out the stud. some say remove the rotor with the hub attached, separate them, and then pound out the stud. some say remove the hub, then the rotor, then pound out the stud and repack bearings and grease. some say it's easy, some say it's hard. WTF? which is it? all the links to manuals i have gotten are to remove things but no one has yet said without a doubt what i do and do not need to remove. i've never opened up or worked on anything really involved with the driveline so i really don't know what to expect.
also, what special tools will i need? one of the posts mentioned i might need a big ass socket, which i don't have.
Old Oct 20, 2009 | 09:03 AM
  #25
fireman1559's Avatar
they r cheap 2 buy and prety easy to fix i broke 4 on mine and a trip to the store and 25bucks later i had 6 brand new studs and lug nuts and maybe an hour later they were all on not to big of a deal in my opion id rather be safe than sorry when it comes to my truck
Old Oct 20, 2009 | 09:46 AM
  #26
CHEEZBURGER's Avatar
How easy it is depends on how rusty everything is and how big your BFH is
Old Oct 21, 2009 | 08:54 AM
  #27
ayoung101's Avatar
ha! well in that case it's gonna suck! cuz my truck is wicked rusty and my BFH is really only a "regular-sized-FH"
bigjstang
Jun 2, 2025 03:56 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
jasonty
41
Dec 23, 2018 01:00 PM
88yodabasket
Jul 13, 2015 01:32 PM
jon.r
Jul 11, 2015 03:34 PM
