brakes, wheel bearings, ball joints
Old Jun 12, 2007 | 09:45 AM
Swansen's Avatar
88pickup 22RE 4wd
i was just wondering if there is anything i might get hung up on or any parts i should make sure to get. I have new calipers, (they were needed) caliper bolts, then all the obvious stuff, pads, rotors, ect. Oh, and i'm also doing the rears, but i'm pretty sure i'm set there, new hardware (springs and such) self adjuster repair kit, shoes, and just turning the drums.
Old Jun 12, 2007 | 12:34 PM
MudHippy's Avatar
You'll need a 54mm Toyota spindle nut socket, or equivalent. You may find you need other things like new spindle nuts or the lock tabs if they are all roughed up. If you do, WabFab has all those goodies.
Click this:http://wabfab.org/products/frontaxle/frontaxle.htm
If it's not too late, I have an upgrade idea for ya.
If you get 88 4Runner shoes they are larger(wider), everything else is the same so they swap right in. And if your turning the drums you shouldn't have any problems, or I'd say get new drums. I got some when I swapped a 4Runner rear end on to my 88. I was stoked, I need all the brakes I can get with 35x12.5s, made a big difference.
Old Jun 12, 2007 | 01:36 PM
Swansen's Avatar
Yeah, i might as well get that stuff, that and i need the socket and gaskets for the hub, was going to do the brakes tonight, but i guess i'll have to hold off till later this week or put off plans this weekend
But yeah, thanks for the advice, and the link, i'll more than likely be ordering some stuff through wabfab. Oh yeah, and it is to late, i already have shoes.
glowz825
Jan 25, 2022 09:28 AM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
