brake plumbing question
Old Apr 8, 2009 | 05:13 PM
sas'd22re's Avatar
im swapping my master cylinder in favor for a v6 1" bore one. i just did a rear disc swap and need to install a residual valve and proportioning valve. im putting both of valves in the engine bay right after the master cylinder....my question is, which order do i put them???
do i go
master cylinder, residual valve, proportioning valve
master cylinder, proportioning valve, residual valve
thanks for the help
Old Apr 8, 2009 | 05:57 PM
one2high's Avatar
I just put the proportioning valve on the rear line at the master on my 94. The brakes work very well at stopping it with a LT1 350 and 35" swampers. I have 85 axles at both ends with original 94 vented rotors on front and the conversion on the rear.
Old Apr 8, 2009 | 06:39 PM
sas'd22re's Avatar
sweet. im definatly gonna be putting the proportioning valve on the rear...i was told to use a 10lb residual valve as well (a check valve/one way valve) to keep some brake pressure on the rear pads. just wondering which order to put the valves
Old Apr 8, 2009 | 08:18 PM
sas'd22re's Avatar
anyone???
fountain
Dec 31, 2015 06:08 AM
CanRunner
Jul 20, 2015 01:29 PM
Johntom240
7
Jul 13, 2015 12:18 AM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
