Brake Pedal Woes
Old Dec 28, 2012 | 02:30 PM
jerry507's Avatar
So your issue was that you (edit: the PO) put in larger volume wheel cylinders, and your master cylinder had to be depressed further to move enough fluid to generate the correct pressures? I think I'm thinking about that correctly.
Right now the only parts of my brake system that aren't new are the LSPV, lines and booster. In my case, the entire axle is the correct one and not mismatched wheel cylinders. I very occasionally get that inconsistent height issue. It'll be nice and firm, but if I push too hard it's sort of give way and then not be firm for a while. Hasn't done it in a while though. I could see that issue arising from mismatched pads and wheel cylinders. The cylinders push too far, pop out and suck air back in when the system relaxes. But I don't think that'd happen with a fully matched rear brake system.
Damn, now I'm thinking about it. That only causes trouble.
Old Dec 28, 2012 | 02:38 PM
stanz's Avatar
Yes, you are thinking about it correctly. What a PITA this has been. I feel really bad for my friend that was doing the work for me on this. He spent several days chasing this until he just couldn't do it anymore. On top of that, he lent me a car to get around and his timing belt broke on me while I had it.
The brakes were part of a whole list of to-do's I gave him to get all 'known' mechanical issues checked off as done. I'm looking forward to that to-do list being put to bed!
Old Dec 28, 2012 | 02:49 PM
ksti's Avatar
Wow! What a freak thing to happen. So your good to go now?
Old Dec 28, 2012 | 03:11 PM
stanz's Avatar
It won't be done til tomorrow, so there's always a chance I guess that the road test finds some lingering symptom of it.
I'm not totally in the clear yet. When I was attempting to get my rear defroster working, I somehow broke something (likely a wire) inside the tailgate that is preventing my window motor from working (there's an entire separate thread on this too). I'm all tapped out paying for repairs (over $1k the past two weeks alone), so I'll be going solo on that one trying to repair it. Desperately need to have my tailgate working again. Once that is done, I'll be in the clear for a while - I sincerely hope!
Old Dec 28, 2012 | 03:20 PM
  #25
ksti's Avatar
Well, from what was found it makes sense.
I sure you will be good to go tomorrow.
As for tailgate should be a 1 fix at least. Post up with results on both repairs.
Old Dec 29, 2012 | 01:15 AM
  #26
wyoming9's Avatar
Red face
What I can`t figure out is how the P.O. did not see the difference in wheel cylinders .
The only ones I could think of that would be so much bigger are the ones used in the Tacoma`s because the amount of extra volume has to be considerable to cause that problem.
I would love to know the numbers to do the math
Well let`s hope that is the end for now.
On to the window!!!!
Old Dec 29, 2012 | 05:26 AM
  #27
stanz's Avatar
...didn't see or didn't care. I've spent the past year unraveling several other hacks that were not immediately self evident. Based on the evidence, I suspect he had an early model 2nd gen 4runner and/or Tacoma as a parts truck and there were several 'close enough' part swap decisions.
Old Dec 29, 2012 | 06:36 AM
  #28
waskillywabbit's Avatar
Gotta love obliviot slacktard POs.
:wabbit2:
Old Dec 29, 2012 | 10:48 AM
  #29
stanz's Avatar
Been driving it all morning. It's definitely fixed!
fountain
Dec 31, 2015 06:08 AM
ty1er
Aug 1, 2015 11:53 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
PopsDad1
Jul 30, 2015 02:21 PM
