Brake issues
Old Sep 2, 2020 | 01:59 PM
Lovinmaryjane's Avatar
Brake issues
Hi... I joined today because I'm having some issues I've never dealt with before. I have a 1994 Toyota Hilux with a 3 inch suspension lift on 33s. It's evergreen pearl in color. Now about a month ago I had a caliper lock up. Of course I replaced it to have the sane issue. I've put calipers on both front sides twice and they're still sticking. If I jack it up after driving it you can hardly move either wheel on the front, but if you break the bleeder valve loose on one side both will free up. I just ordered a master cylinder, but have never had any issues like this with a master cylinder. Could that be my issue, and if it isn't what else could it be?? It also has new lines and hoses all the way around. I really need some help here. Could it be a break booster?? Idk it matters, but it doesn't have abs and was built in Long Beach, California.
Old Sep 2, 2020 | 02:46 PM
millball's Avatar
Rod in brake booster may be adjusted too long, so that master cylinder cannot return to bleed-off position.
Old Sep 2, 2020 | 03:06 PM
thank you... I'll try anything. This truck is my favorite, and kinda my mistress lol
Old Sep 2, 2020 | 04:45 PM
Paul22RE's Avatar
5 Year Member
Nice truck!
Old Sep 2, 2020 | 10:41 PM
the_supernerd's Avatar
I had the master cylinder get stuck in a 4Runner once, and it was similar to your problem. If cracking the bleeder frees both calipers, then the problem not in the calipers. I agree the rod in the booster could be a problem, but if has not been adjusted recently then it is probably the master cylinder itself. Make sure the rod is adjusted properly when you install the new master cylinder, and that should cover both of the most likely problems.
James 71
Mar 26, 2020 11:54 AM
rustyShake
19
Nov 26, 2017 02:23 PM
HeroEnVec
Jun 6, 2014 04:54 AM
koamanaz
Dec 26, 2012 04:50 PM
crownjewel
Oct 1, 2012 02:49 AM
