brake fluid leak between master cylinder and reservoir
Old Aug 5, 2011 | 02:55 PM
8yota6's Avatar
i am leaking brake fluid between the master cylinder and reservior, is there suppose to be some kind o-ring between there? looking @ the haynes manual it shows some kind of o-ring or gasket.
Old Aug 5, 2011 | 03:11 PM
Terrys87's Avatar
I think it is a 17 mm socket to take the resevoir off and there is a rubber seal/gasket that goen in between the tank and Master Cylinder. Might try just tightening it a little bit first and see if that fixes it.
Old Aug 5, 2011 | 03:21 PM
8yota6's Avatar
tried tightening it, there is no seal between the res and cylinder so thats should be the problem. now the question is, where can i get that seal?
Old Aug 5, 2011 | 03:44 PM
angrybob's Avatar
Check the pic - is this what you have?
The diagram shows a "RING(FOR BRAKE MASTER CYLINDER RESERVOIR, NO.2)" (P/N 90562-18151) btwn the m/c and reservoir. Probably a dealer only part. This does not appear to be an o-ring but rather a collar to connect the two, but I can't tell for sure and I'm not near my vehicle at the moment. There is no other part listed for this joint.
Is the "ring" cracked / damaged?
Make sure the hose running to the other circuit is sealed and not damaged as well.
Attached Thumbnails brake fluid leak between master cylinder and reservoir-8-5-2011-4-41-47-pm.jpg
Old Aug 5, 2011 | 04:22 PM
8yota6's Avatar
Yep thats the part that I am missing. I may have lost it when I changed t he master cylinder. Thx
Old Aug 6, 2011 | 02:59 AM
Terrys87's Avatar
I am sure the dealer ship has one, but you could try Orielly, Auto zone, and they have rubber seals that would probably work. The seals wont be in the customer isle, they have them in the back with their parts.
Old Aug 6, 2011 | 01:53 PM
The MAN's Avatar
better to buy the toyota part that you know fits than something that "kinda" fits but isn't designed for brake system use from the parts store... I wouldn't chance it on a crucial safety system like this
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
the1998sr5
Jul 16, 2015 06:20 AM
Rkellerman
Jul 12, 2015 08:42 AM
