Bodyman help
Bodyman help
I'm trying to strip a frame for a POR 15 application. I've been using a wirewheel on an angle grinder. I don't want to use a grinding wheel because I think that would be too abrasive and cut in to the metal.
Is there something more aggresive then a wire wheel but not as harsh as a grinding wheel?
Would a scotchbrite disc work? Is there something I don't know about?
You could get a flap disk for your angle grinder. It will take off material quicker than the wire wheel and leaves a nice shiny surface. You can get them in different grits. I would get something over 100 grit.
Flapdisc. I buy mine from http://www.lehighvalleyabrasives.com/servlet/StoreFront
a wire wheel is PERFECT ...
If you check the application instructions .. removal of "loose scale" is all you need , and actually the BEST
Alan's Classic
Jun 17, 2020 12:48 PM
nothingbetter
95
Mar 25, 2015 05:04 PM
biker1
Apr 29, 2008 08:13 PM
