body swap ?'s
Old Jan 24, 2006 | 08:55 AM
suprathepeg's Avatar
I'd imagine that TTORA is a shop somewhere. All that like is ment to do is show you that is can be done and that its actually better then a SAS on a IFS frame. Go to 4x4wire.com and pirate4x4.com and post up the question "SAS on a 2wd frame howto?" someone there must have done it at least once that could guide you. Although it really shouldn't be any different then a SAS on an IFS frame.
Old Jan 24, 2006 | 10:16 AM
Radyota's Avatar
I think TTORA is toyota truck off road association, just a local 4 wheeling club. I think the easiest thing to do in your situation is to swap the fuel injected engine into the 4wd chassis, swap the 2wd gas tank/fuel lines to the 4wd frame (the 2wd tank isn't as deep so just swapping the in-tank fuel pump is not an option), mount your 2wd cab/box, and swap out the wiring harness from a fuel injected truck. As long as the interior of the cab is stripped to R&R the harness, it's a good time to do a clean wiring job on an awesome sound system! That's the best option to take if you don't want to weld anything.
Old Jan 24, 2006 | 10:44 AM
Hondadik's Avatar
will the 91 body fit on a 83 frame or any of the older year trucks that already have the sfa?
Old Jan 24, 2006 | 10:52 AM
You could make anything fit if your willing to make it work. The pre 84 frame is different and somewhat weaker. You could use a n 84/85 frame. If you don't want to weld then yes swap the frame. The SAS is really not that hard a concept to get your head around and some guys do them in a weekend, you will have to either weld yourself or find a good friend to do it for you.
Old Jan 24, 2006 | 11:05 AM
  #25
Hondadik's Avatar
i don't want to weld anything, so the 84/85 has the sfa? will i have to do any mods to put the 91 body on or will it bolt right up?
Old Feb 12, 2006 | 08:42 AM
  #26
Radyota's Avatar
I guess you'll have to get out the 'ol tape measure and measure the distance between mounting holes on both frames and compare. The boxes are interchangeable, but I don't know about the cabs.
Flying91
45
Apr 11, 2024 04:39 PM
GeoRoss
Jul 24, 2015 03:03 PM
Backcountry411
Jul 24, 2015 08:06 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
yourrealdad
Jul 21, 2015 11:13 AM
