Body swap
Old Mar 23, 2008 | 04:05 PM
Justinvd's Avatar
Body swap
When i buaght my runner it was rebuilt to stock specifications. I have recently bin doing some body work and to my horror i find out that the person was a bondo freak. There is bondo on everything. I always wondered why when i pounded the dents out there was such crazy cracks. Anyways i dont want this body anymore cuz there is like a cm of bondo of everything.
Any help would be great, Thanks Justin
Old Mar 23, 2008 | 06:28 PM
samiam39's Avatar
I believe you would need to move a few of the body mount points as they are not the same on the pickup and fourrunner frames, not a big problem if you have a welder and time
Old Mar 23, 2008 | 06:53 PM
abecedarian's Avatar
You will most likely run into an issue with VIN numbers. Seems that registrations and VIN's are tied to the chassis so if you change the body, you're changing your VIN, just like buying a new vehicle. So, you'd need to have a release on file for the old VIN just so you could prove you own it and consequently put it on your frame.
Old Mar 23, 2008 | 07:49 PM
Justinvd's Avatar
Yeah, ill prolly just rebondo my runner, buy a 1983-1985 pickup truck and swap my axles and good leafs into it and put the stock axles in my runner and sell it haha.
Old Mar 23, 2008 | 07:52 PM
It sucks, i know. Canadia (hehe) is probably not that much different than the USA. The VIN identifies a vehicle and is part of the chassis/'cab'. So when you change 'cabs' you're actually (legally?) changing vehicles.
Your other option is lead filler / sheet metal replacements.
Either way... good luck.
Old Mar 23, 2008 | 07:58 PM
Justinvd's Avatar
I have no patience for body work. The only reason i am doing it is because i finally got my new fender flairs for the passenger side of my truck so i am bashing out the dents. I wouldnt even care if it was banged up but that much bondo on everything is just nasty. Who knows what its covering right? i almost want to just wire wheel/belt sand the hole thing and rock guard the hole body, it is my baby haha i do everything in it. But i think its time for a extended cab pickup with a flat bed.
Old Mar 23, 2008 | 08:13 PM
Hopefully you'll get lucky and new 'glass fenders and maybe new doors fix everything so you don't have to change cabs.
Alternately, roll bar the whole thing and rock with it!
Flying91
45
Apr 11, 2024 04:39 PM
GeoRoss
Jul 24, 2015 03:03 PM
Backcountry411
Jul 24, 2015 08:06 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
yourrealdad
Jul 21, 2015 11:13 AM
