body ground?
Old Apr 17, 2009 | 05:54 AM
yota4life6's Avatar
body ground?
on my 95 4runner 3.0, I get a low hum/buzz sound out of my speakers... not sure what stereo mods were done over the life of the truck, but its quite annoying and curious if this has to do with the ground? Maybe not the actual truck "grounding", but maybe the radio ground?
Can someone tell me where my main body ground connection is? Its worth checking I guess..
thanks alot
Neal
Old Apr 17, 2009 | 05:56 AM
PlugItIn's Avatar
does it have an aftermarket cd player and amps in the back, or stock? Does it get louder when you hit the gas?
Old Apr 17, 2009 | 03:45 PM
socal_style's Avatar
^ Yeah good starting questions.
If its stock, check all the grounds.
If it is aftermarket, you may need to rewire. You may be getting electrical interference, also known as engine noise from the wiring set up. Separate the 12v wire from the RCAs and speaker cables, running them on separate sides of the truck. Then make sure that the AMP ground is good and solid. Check your RCAs for kinks and stuff like that.
Old Apr 17, 2009 | 04:18 PM
abecedarian's Avatar
Non-resistor spark plugs and / or ignition wiring could cause a buzz, as could a spark-plug wire that is damaged and is arcing to something, however the buzz would change in frequency with the engine rpms.
If the stereo / amplifier is balanced/transformerless, aka BTL (most modern stereos are and you can tell: if the stereo / amp has a [-] wire for each speaker it's BTL and if it has a common [-] wire for front/rear or left/righ or even all speakers, it's not), if one of the speaker wires grounds out that could cause a buzzing as can having the amplifier gain turned up too high or having speaker wiring or amplifier cabling running near the ECU (on the right side of the passenger cabin).
Old Apr 21, 2009 | 09:21 AM
yota4life6's Avatar
thanks guys.. yeah, its an aftermarket head unit that looks like it used to have an amp and speakers... Found some wiring here and there, but all equipment was taken out.. I assumed it was something with the stereo.. It does change freq when I change RPM..
Blamalam
Mar 12, 2022 07:34 AM
montanatruck
Feb 26, 2017 07:07 AM
Sep 4, 2015 09:27 AM
ToyoToler
Aug 8, 2015 08:43 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
