blown head gasket help in v6 3.0 liter
Old Apr 30, 2008 | 03:35 PM
bansheebrofasho's Avatar
hey i just blew the headgasket in my 95 4runner. it started smoking really bad then stopped smoking so i went to drive it home and it over heated. after putting about half a gallon of water back in it i made it the rest of the way. so i went to shucks and bought some engine sealer to last me a couple more months. after i followed all the steps my engine doest eat up the coolent any more or smoke at all but it still overheats.. could that be because theres water in my oil?? or possibly my thermestat? or just the same old blown headgasket? it runs a lot different and seems to be running perfect until i idle it for over about 8
minutes then it starts to over heat.. any help would be great.
thanks
miles
Old Apr 30, 2008 | 03:54 PM
MonsterMaxx's Avatar
don't run it until you fix the headgasket, otherwise you'll be rebuilding the whole thing
Old Apr 30, 2008 | 03:59 PM
LTrunner's Avatar
if you got water in your oil it's the HG...i agree with monstermaxx though if you run the enige you'll scerw it all up....you'll mix the water/oil sludge into all the internal bearing and destory them, also it will damage the rings so you should park it
hiluxinargentina
Sep 30, 2015 05:51 PM
Matthew Perez
Sep 28, 2015 05:43 PM
mtrdrms
Sep 26, 2015 07:12 AM
icentropy
Sep 10, 2015 05:03 AM
FJtoyman
Sep 8, 2015 04:47 AM
