Blower motor not working on my1994 Toyota T100
Old May 21, 2017 | 03:48 PM
WalterF's Avatar
Light comes on for AC button, relay is clicking when I slide the fan speed control lever. Does not work on any speed. Also, AC clutch on the compressor is not engaging
Old May 21, 2017 | 04:56 PM
dropzone's Avatar
Fossilized
possibly a bad blower motor resistor...was this all of a sudden or die over time? All your fuses good?
The blower motor resistor can cause the switch to go bad. this was what I experienced. after fixing this stuff my fan worked on all speeds and i had AC again
Originally Posted by dropzone
I went ahead and replaced the blower motor resistor today after doing a little more research and learning it could contribute to killing the fan switch
I'd like to have a talk with the genious at Toyota who decided to put a failure prone point in such a convience place (tucked under the blower unit on the right side tucked up against the firewall)
I went ahead and pulled the glove box hoping for a little more room.
got it out after a few minutes and cussing, not the easiest thing to get out.
if you need to having a 7mm wrench helps on the back screw/bolt, you can get to the visible screw with a screwdriver or nut driver.
new one on the left, old one on the right..old one was slightly tarnished.
new one should offer a few years of good service
so a bad resistor that seemed good had fried my switch
replaced it and the resistor and life is good again
soouuzaa89
May 23, 2017 10:28 AM
defrag4
3.4 Swaps
May 20, 2017 06:51 PM
