bj spacers and a one inch torsion bar crank with 1 inch diff drop
Old Dec 3, 2010 | 06:04 PM
gary96360's Avatar
im about to buy 1.5inch ball joint spacers. but i also want to crank the t bars about an inch with a diff drop. i just put in manual hubs the other day. would the truck be super hard to align? i was checking out some threads today and acedarian said this,
Yeah.
Putting the BJ spacers on pushes the LCA down, pulling the lower balljoint inwards (since the LCA / lower balljoint is already below horzontal). So you end up \ /.
Cranking the t-bars pushes the UCA down, pulling the upper balljoint inwards since the UCA is below horizontal (and moves the lower balljoint inwards too), but due to the BJ spacer, the upper BJ moves inwards at a faster rate than the lower and with only a little bit of crank, the upper joint moves inside of the lower joint causing / \.
so if i stick in the bj spacers and crank the t bars a bit, will the tires be more like this l l ?
Old Dec 3, 2010 | 06:13 PM
waskillywabbit's Avatar
Install the bj spacers and see how it sits. Then crank the tbars if you want and get an alignment at somewhere that has someone who has a clue what they are doing.
:wabbit2:
Old Dec 3, 2010 | 06:14 PM
gary96360's Avatar
also im running 33's with 15x10 rims with -46 mm offsett backspace 3 5/8 will they fit with this lift?
Old Dec 3, 2010 | 06:27 PM
4Crawler's Avatar
They should clear the upper control arm fine, but with the added width/backspacing over stock, you may need to do some fender trimming up front:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
Old Dec 3, 2010 | 06:34 PM
gary96360's Avatar
ive bashed in the pinchweld, hammered the fender and trimmmed it up a bit. now theres no rub with a 3 inch body lift.
Old Dec 5, 2010 | 08:31 AM
BackGateYota92's Avatar
ya man i have had 3" body lift, bj spacers and a inch of crank and i havent had a problem with allighnment to much. i just tell them to do the best they can. as far as tires and wheels go i had 33x13.50 ltbs on 15x12" rims with either 3" or 3.5" of backspacing and the only thing that rubbed was the lugs on the valance
88sasturbotoy
Jan 30, 2026 01:57 PM
jerusry
Oct 19, 2015 05:28 PM
Sep 4, 2015 09:27 AM
Yotoder865
Jul 9, 2015 07:51 PM
