"Big 3" Mod on '87 4Runner
Old Aug 18, 2011 | 06:36 PM
angrybob's Avatar
"Big 3" Electrical Mod on '87 4Runner
Big 3 mod is upgrading:
1) Battery negative to chassis
2) Alternator to battery positive
3) Chassis to engine
I decided to upgrade my electrical wiring due to adding the following:
8500# Superwinch
12-place auxiliary fuse box
2 150W inverters (daughters gotta charge their DS's)
Optima YellowTop
and these are going on this weekend:
1 400W inverter
Stereo w/ 240W amp
Flex-a-lite fan 674 (draws 40A peak at startup & 19A running)
130A Denso rebuilt alternator
and an ARB locker compressor in a when the summer heat goes away.
Needless to say the stock wiring will be taxed after this weekend if not already. I picked up Stinger brand 1/0 AWG amp wire and have all of the materials.
I've also read up on the process and understand everything but one item. All of the write-ups that I found say to leave the stock alternator to battery positive (fuse box in my case) wiring in place.
WHY?
I understand that current flows through the path of least resistance which will be the new wire, so why eave the old? Sake of ease?
If so, couldn't I just bypass the fuse box, go directly from the alternator to the battery, and install my own inline fuse?
Any help would be appreciated.
Old Aug 20, 2011 | 07:48 AM
92 flatbed's Avatar
8500# Superwinch
Optima YellowTop
1 400W inverter
Stereo w/ 240W amp
WHY?
what would feed the fuse box if you bypass it? you would be better off leaving the original wiring there, and adding a larger wire to the battery.
Old Aug 20, 2011 | 09:11 AM
angrybob's Avatar
Yessir...that is the plan. Leave it and install direct feed from the alternator to the battery with an inline 150A fuse.
Thanks.
Old Oct 18, 2011 | 10:57 AM
86yota22r's Avatar
Where can I find a thread about just the "Big 3 Mod"??? Every time I search I can't find anything actually explaining this mod.
A link would be awesome. Thanks.
Old Oct 18, 2011 | 12:00 PM
angrybob's Avatar
Outside of this site. Google "Big 3 Mod" and it will bring up audio forums with good write-ups.
icentropy
Jul 11, 2015 07:21 AM
tpd143
Jul 7, 2015 09:06 AM
Nickdigg
Jul 7, 2015 06:04 AM
