Beware Of Clutch Bracket Fatigue!
Old May 27, 2013 | 01:15 PM
  #121
Hezzy's Avatar
This is why I cruise these forums! My clutch pedal has been making a annoying pop ever time its depressed and I could not trace it down! Now I have an idea of where to start looking!
Thanks yotatech!
Old May 27, 2013 | 03:14 PM
  #122
slo6i's Avatar
I had this problem with a civic that I previously owned.
I welded it back together, and it felt like a new car! I now will go out and check my yota as my clutch feels weak. I dont get the pop though.
Old Aug 20, 2013 | 01:57 PM
  #123
NickS022's Avatar
I was told the metal was to thin to weld I was surprised when they said that what amperage are u using and yes removing the lower part of the dash help a lot just keep track of your nuts and bolts
Old Nov 26, 2013 | 05:10 PM
  #124
RylerTust's Avatar
Don't know if this has been posted, but the reason mine cracked was cause the mount which is welded to the cowl broke allowing the perch to flex and crack the bracket. So it left a noticeable crack in the cowl. Please remove the vowel cover and pull the strainer on the furthest driver side opening and check if yours is cracked. Can't believe they made the firewalls on these so thin. Just a heads up for everyone.
Old Jan 16, 2014 | 10:28 AM
  #125
Natosports's Avatar
Mine doesn't have any crack signs. Should I just take it out and weld it before hand? Or at least put a clutch pedal plate in there for support? Please advise. (See pics)
Attached Thumbnails Beware Of Clutch Bracket Fatigue!-los-angeles-20140116-00071.jpg   Beware Of Clutch Bracket Fatigue!-los-angeles-20140116-00072.jpg   Beware Of Clutch Bracket Fatigue!-los-angeles-20140116-00069.jpg
Old Jan 16, 2014 | 10:33 AM
  #126
RylerTust's Avatar
Always better safe than sorry. Check your cowl too.
I added a brace from clutch to brake perch cause when it breaks it's cause the flex from clutch Tword brake in a forward right hand motion.
Old Jan 26, 2014 | 08:57 AM
  #127
Gabe1991's Avatar
Broke this week
Thanks to all these posts, I've been able to kill 3 birds with one stone.
Clutch pedal broke in the same spot as others. I removed the steering column to get the bracket out. As others have said, PITA but the bracket came out easy this way. The only thing now, is I forgot to mark where the clamp and set screw went on the steering column shaft.
The plastic piece behind the ignition switch was loose, so tightened up that one screw.
Working on my starter now that is covered in oil. Gotta do some work. Not sure where all the oil is coming from.
Gabe
Old Jan 28, 2014 | 06:15 AM
  #128
RylerTust's Avatar
Gabe, check the opening in the cowl on the drivers side. The clutch mounts to that too. See if it's cracked.
Old Jan 28, 2014 | 06:35 AM
  #129
Natosports's Avatar
Gabe, how many miles on your truck?
Gabe
Old Jan 31, 2014 | 08:17 AM
  #130
dannonannon's Avatar
I went the route of removing the steering column. Made the job reasonably easy. I couldn't fully remove it due to aftermarket wiring, but was able to hold it up and out of the way with one hand while removing/reinstalling the bracket with the other. Hang it by the top 2 nuts when you don't need it out of the way. Also make sure your brake booster is fully out of the way. You might need to block it up to hold it while the studs are out of the fire wall.
I went with a new OEM bracket ($140 plus shipping) and had a brace welded on and the far left spot welds reinforced (professionally, $40). The brace made a big difference, I could flex it by hand before, but not after. Pics below.
Also not mentioned anywhere that I've seen, there's supposed to be a plastic bushing to make the pin-hole in the pedal tight and silent. Toyota P/N is 9038904002. That should help against the pin and hole wearing out of round, like mine did. I fixed the out of round pin-hole by filling the worn area with JB Weld. Used a round file to make it roughly the right shape after filling, then conveniently the brake pedal pin is exactly the right size to drive the hole back to perfectly round. Worked like a charm.
Old and new frames:
Pedal hole JB Weld repair and new bushing:
Old Jan 31, 2014 | 08:22 AM
  #131
Guess google drive doesn't work for embedding photos here... The full set should be available here for anyone who's interested: https://drive.google.com/folderview?...UE&usp=sharing
Old Jan 31, 2014 | 09:49 AM
  #132
BMcEL's Avatar
You can embed any image from anywhere, as long as you can get the direct link to it. On your link above (using Firefox), click on a picture to open the preview, then right-click > copy image location. Then come here and type [IMG]link.you.copied[/IMG]. Internet Explorer is a little different...either right-click > copy or right-click > properties and copy the URL.
Here's one as an example:
Old Jan 31, 2014 | 10:55 AM
  #133
Gamefreakgc's Avatar
Mine completely broke, as in the pedal fell on the floor broke.
I took mine to a fabrication shop and had it welded back on for $125 at a local fabrication shop. It's never coming off again (for good or for bad) and I didn't have to do any of the work myself. Just a thought for those who have this problem.
Old Feb 18, 2014 | 12:45 PM
  #134
GMartin1991's Avatar
RylerTust, I checked the cowl and everything is good.
NatosSports, I am at 298,896 miles. I want to hit 300K then think about a rebuild.
Truck runs great now.
Gabe
Old Feb 18, 2014 | 04:55 PM
  #135
Natosports's Avatar
Thanks for the response. I'm at 127,000 miles. The clutch squeaks but there are no signs of cracks.
Old Feb 18, 2014 | 05:00 PM
  #136
Matos, look carefully. That's how mine started out until I heard a loud pop one day and that's when it was obvious.
Old Feb 18, 2014 | 05:08 PM
  #137
Natosports's Avatar
What do you suggest I do? What about the "If it ain't broke, don't fix it?"
Old Feb 24, 2014 | 03:10 PM
  #138
jgrant721's Avatar
Clutch Bracket Gave Up Yesterday
Exactly the same scenario as many others; driving down the road, shifting gears, *CRACK*, hard to shift, oh &%$#!
Thanks to a quick search on Yotatech I knew exactly where to look to confirm a cracked clutch/brake bracket and get lots of tips on how to repair. What a great community!
I removed the drivers seat , lower dash, heater ducts and steering wheel (all pretty quick and makes the job way easier). Be sure to mark the splines on the steering shaft to get the right alignment on reassembly.
Removed the 4 bolts holding brake booster on (they go through the clutch/brake bracket, and through the firewall). In the engine compartment I removed the 2 nuts from the clutch master cylinder and the bolt on the left side of the booster holding the brake hardlines to the firewall. This allowed backing out the master cylinder and the booster to get the clutch/brake bracket out.
Removed the connecting pins from the brake and clutch actuators, disconnected all electrical wiring and the remaining bolts from the bracket. A bit of wiggling and it was out.
You can see from the pics what I found; typical metal fatigue. Since I have a basic MIG welder I figured the fastest/cheapest solution would be to fab a strengthening brace and weld it in.
More in following post...
Attached Thumbnails Beware Of Clutch Bracket Fatigue!-clutch1.jpg   Beware Of Clutch Bracket Fatigue!-clutch2.jpg   Beware Of Clutch Bracket Fatigue!-clutch3.jpg
Old Feb 24, 2014 | 03:12 PM
  #139
jgrant721's Avatar
Clutch bracket fix continued,,
I cut a 2" x 1" piece of steel about the same gauge as the bracket and trimmed/bent it until it fit snugly. A bit of sloppy but effective welding, grind down the nasty bits, spray everything with a bit of rust paint and ... DONE!
Another couple of hours to carefully put everything back together (no leftover bits - woohoo!) and she shifts better than ever. If the original lasted me 23 years lets hope the repair lasts half that!
Thanks again to all those who have gone down this path before me!
Jim G.
Attached Thumbnails Beware Of Clutch Bracket Fatigue!-clutch4.jpg   Beware Of Clutch Bracket Fatigue!-clutch5.jpg   Beware Of Clutch Bracket Fatigue!-clutch6.jpg
Old Mar 2, 2014 | 10:28 AM
  #140
"G"'s Avatar
"G"
Yours is probably fine because you are one of the few that has a master and slave in proper working order. (bled properly and not neglected) Also your clutch fork and release bearing are greased properly.
