Bad miss
Old Jan 20, 2015 | 11:55 AM
bswarm's Avatar
Ah yes, Auxiliary Accelerator Pump. Many years since I rebuilt carbs.
Old Jan 20, 2015 | 12:01 PM
87blyota's Avatar
Well let me ask you this to test it are you supposed to pull the vaccum hose while the truck is running or off? When I did it I did it with it off
Old Jan 20, 2015 | 12:04 PM
bswarm's Avatar
Off, any fuel in the vacuum hose or dripping out of the fitting means the diaphragm has a hole.
Old Jan 20, 2015 | 12:13 PM
87blyota's Avatar
OK well no fuel comes out when I pull the vacuum hose
Old Jan 22, 2015 | 10:26 AM
  #25
87blyota's Avatar
alright just a update i replaced the ignition coil and so far the problem has not happened. the old coil had a good amount of corrosion in it and had a small crack on the back. no all that is left is to find out why i still blow black smoke whenever i rev it.
icentropy
Sep 16, 2020 02:47 PM
Sleaker
Aug 26, 2020 06:03 AM
jasonty
41
Dec 23, 2018 01:00 PM
TDonkey
Jul 26, 2015 10:14 AM
