BAD compression... is it over?
After having an intermittent idle problem (sometimes shuts off at stoplights) and looking over everything, replacing sensors, and a good tuneup, I did a compression test. Results as follows:
Cyl 1 110psi
Cyl 2 45psi
Cyl 3 60psi
Cyl 4 45psi
Cyl 5 150psi
Cyl 6 10psi
Is there anything I can do short of a rebuild? It would cost more than the truck is worth, so I'm not to fond of the idea. Has it run it's course?
Cyl 1 110psi
Cyl 2 45psi
Cyl 3 60psi
Cyl 4 45psi
Cyl 5 150psi
Cyl 6 10psi
There is the 3.4 swap option, install a lower mileage used engine, rebuild, or install remanufactured. I've seen reman'd from about 1700.
There was an entry on craigslist near me for a 5vze and trans/transfer case for 1500, no harness though.
Have you done a cylinder leakage test? I have seen where one or more valves haven't fully seated due to bad valve adjustment, so the cylinder never sealed. It could be as simple as a valve adjustment. If you have an air compressor, i think Harbor Freight had teh leakage testers for about $20.
Agree with last post. I suspect there are very few 3.0's that have ever had their valves adjusted because its so difficult to perform and very expensive. If you are not burning oil out the tail pipe, then your valves need adjusting. Over time they retract into the head and loose their very small clearances from the factory. Pack a dam lunch if you try and do it yourself. I suspect the dealer would want at least $500 to do the work. I have used a very large flat blade screwdriver to hold the valve spring down enough to remove the adjustment shims with a magnet. I have had some luck swapping them around, flipped over for a new surface, and getting the valves back in their adjustment clearance ranges.
My $0.02 but been there and done that....
Here is the one I got. i am pretty sure it was on sale when i got it (they always have sales) but still $35 isn't too bad. Basically hook it up, and remove your oil fill cap and radiator cap. If you see it bubbling and hear it out the radiator, you have a blown head gasket, if you hear it out the oil filler cap it's most likely bad rings, if it's out the exhaust or intake, then it's the corresponding valves.
http://www.harborfreight.com/cpi/cta...emnumber=94190
BTW, yeah TDC for each cylinder. Once you find #1, you can go in firing order and use the distributor to help you verify, the rotor is going to point ot the wire of the cylinder at TDC.
Blamalam
Aug 16, 2015 12:29 PM
nonstop
7
Aug 11, 2015 09:26 AM
