Bad clutch slipping, what is going wrong with it???
Old Apr 14, 2011 | 09:18 PM
justin_4runner's Avatar
fill the reservoir, and open the slave if u can get clear hose on it and bleed it, using the end of the with your finger over it to not let it pull the fluid back put almost a full reservoir threw it. it should then have enough fluid threw that there should be no more air.
Old Apr 14, 2011 | 11:57 PM
SoCal's Avatar
My 2 cents on bleeding the reservoir..... open the Clutch slave bleeder 1/2 to 3/4 a turn put a hose on the nipple and the other end of the hose in a glass Jar with fluid in it.
Fill Reservoir and pump clutch pedal Do Not let Reservoir get low while doing this.
this way makes it a 1 man job.
Ironmike4x4
Feb 3, 2016 11:13 AM
thefishguy77
Jul 30, 2015 10:59 AM
PlayAwhile
Jul 20, 2015 11:36 AM
1996Taco
Jul 20, 2015 12:02 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
