Aux. fuse panel, switched?
Old Feb 14, 2007 | 06:30 AM
curtiswyant's Avatar
Hi, I want to add an aux fuse panel so I don't have to splice into my existing wiring to add extras (CB, GPS, etc). I would run a fused wire from BAT + to the fuse panel, then I would like to add heavy-duty inline switch between the fuse panel (always on) and the accessory outlets to prevent drain. Should I use a switch or do I need a relay as well? The extras won't be drawing much power, I'm only thinking an overhead light, CB, GPS, and maybe a 110V inverter. Any help would be appreciated. Thanks!
Old Feb 14, 2007 | 06:37 AM
amgraham's Avatar
You should be ok to run just a switch. Make sure it is rated for enough amperage for what you will be running on the outlets.
I put my aux fuse panel behind the driver's kick panel in my truck and it fit perfect. I'm also going to run a cable to have one in the back as well.
Old Feb 14, 2007 | 08:43 AM
Jake97T's Avatar
I used a painless wiring kit with 3 fulltime hot and 4 ingition hot wires for all my accessories. It was a little spendy but it saves alot of headaches as i add more, comes with a fuse block, relay, and all mounting harware, keeps it clean and i dont have to remember to flip a switch to not drain my battery.
Old Feb 14, 2007 | 09:12 AM
rezrunner92's Avatar
Jake, got a link? I want one of those, I saw a couple on this site yesterday.
Old Feb 14, 2007 | 09:14 AM
mastacox's Avatar
I have the same one, let me find the link at Summit racing real fast...
...This is it: Painless Cirkit Boss 7-circuit Auxilliary Fuse Block, has 3 constant-hot circuits and 4 ign-hot circuits. At $60, it's still worth every penny. It has a built-in relay so all you have to do is tap into an ign-hot source like your cigarette lighter or ignition system somewhere. I tapped mine into the ECU's power cable because I only wanted it to turn on when the key was in "ON" rather than "ACC," but tapping into the cig lighter would work great for CB's and the like.
I run my 350 watt inverter off of two of the constant-on circuits in parallel, and then use the ign-on sources for my Piggyback ECU, Wideband O2, and Gauge.
80Truck
Oct 12, 2025 07:25 PM
okamikai
Apr 30, 2018 10:19 PM
JHalcyonM
Aug 4, 2015 01:19 PM
TDonkey
Jul 26, 2015 10:14 AM
rushw
Jul 18, 2015 01:46 PM
