ATM transmission flush question
Old May 1, 2010 | 08:17 AM
swerks's Avatar
I have a 86 4runner with 200000 mi on it. I just had my torque converter and pump replaced but I'm sure it was filled with standard fluid and I would like to go with synthetic. should I do a flush ???
Old May 1, 2010 | 08:55 AM
yayfortrees's Avatar
I wouldn't spend the time or money to flush it with synthetic. Clean gear oil is good gear oil. I also don't recommend switching to synthetic on high mileage vehicles. Usually that applies to motor oil, but since the transmission has seals and such as well, I wouldn't recommend it.
I would just run it with the fresh gear oil!
Old May 1, 2010 | 11:48 AM
swerks's Avatar
there was synthetic in it before the torque converter was changed
Old May 1, 2010 | 12:20 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
No, you'll wash out the clutch material... And if they're wore enough, they'll stick...
I hate tranny flushes, or even changing the fluid... My skin crawls every time b/c I never know if that was the "too much".
Old May 1, 2010 | 12:36 PM
swerks's Avatar
so would not syn fluid allow for longer periods between changes ????
Old May 1, 2010 | 12:43 PM
I'm sure it would, but the question to me is how much ground has your AT covered since 1986? i.e it's not in like new condition...
If it's been rebuilt disregard anything I've said...
the1998sr5
15
Jul 14, 2020 08:35 PM
chuckross1957
Jun 28, 2019 10:19 PM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
jjrbus
Jul 19, 2015 02:06 PM
jjrbus
Jul 17, 2015 07:06 AM
