anyone know where this bracket goes
my 22re rebuild is stretching on towards over a six month long ordeal. nothing but time, right? i work seven days a week, give me a break, i hear enough from my wife about it. anyways, i am within hours of crankin her up.
i've had a friends truck over to look at and try to see if i can find where this bracket goes but i just don't see it. i have no clue. here is a picture http://home.midsouth.rr.com/norwoodstuff/bracket%3f.jpg any input would be appreciated.
thanks,
jess
thanks,
jess
power steering bracket. the single hole goes to the the front of the block. when you have your timing cover on, you'll notice theres a hole about 1/2 down on the front, right side. thats where that bolts too. short side bolts to the front of the power steering pump, the higher side bolts to the back.
pic of the bracket installed, lower part bolted to the front of the block, just to the right of the timing chain cover
this is on the front of the pump
this is on the back of the pump
thanks a ton. if i wasn't so sick i'd go put it together right know. i've been trying to figure this out for days. i post it on yotatech and bam it's done. what was i thinking? your the man.
scott90
Oct 4, 2015 09:21 AM
Brodetski
Sep 30, 2015 11:50 PM
