Antenna help!
Old Feb 23, 2008 | 03:07 PM
91Toyota's Avatar
Antenna help!
My antenna used to move back and forth freely. At highway speeds it would tilt back. Now, today I partially took off the front fender so I could see behind it. In doing so, I did not see how to remove the antenna. So, I tried tightening it and it was getting better then all of a sudden snapped off. Now I am left with a little tiny nub sticking out and I can't get it off to replace it. I put a nut on the nub and a bunch of JB weld. So, hopefully I can just turn the nut and the broken off antenna piece will come off. Do you guys have any suggestions? How should I get it off differently?
Thanks
Old Feb 23, 2008 | 03:26 PM
mudtoy1986's Avatar
well ive got an idea go to the local salvage yard and get a new mast maybe u can get the old on e out with a pair of vice grips but at the botom of the antena there should be a lil metal strap about where the fire wall starts sloping back u might have either a roted out strap or the bolt fell out
Old Feb 23, 2008 | 04:48 PM
stormin94's Avatar
You take the antenna off from the exposed part on the top. twist, and it'll come off. But if you have an auto antenna, I dunno. If you are looking to completely replace your antenna(regular one), there is some funky looking stuff just above the fender line that you have to take off, and then the rest will just slide out the bottom.
Old Feb 23, 2008 | 05:52 PM
91Toyota's Avatar
Thanks...I got it out. The problem was is that I could of just bought a new antenna if I could have got the old piece out but I couldn't. I could have cut the line but the antenna piece still would have been in there. So, I cut the grommet and the plasticy piece off and slid it through. Will a late 80's antenna work?
Old Feb 23, 2008 | 06:02 PM
stormin94's Avatar
The late 80's will probably work. If you can get it for less than $15. If not, you can always get an aftermarket one.
Old Feb 23, 2008 | 07:27 PM
91Toyota's Avatar
I was thinking...could I somehow mount a cb antenna low onto the firewall and have it stick straight up out of the antenna hole. If not...then I will get my $5 antenna.
zombie_barbarossa
Oct 2, 2015 10:54 PM
tazman1972
11
Sep 28, 2015 10:32 PM
shisha1999
Sep 20, 2015 11:35 AM
Ilovemountains
Sep 15, 2015 04:17 AM
msged2007
Aug 22, 2015 07:46 PM
