alternative fuel???
Old Jul 20, 2007 | 04:06 PM
  #41
FredTJ's Avatar
Originally Posted by thefallman
<SNIP>
I mean jeeze whats it doing to your insides, when you drink vodka (pretty much 90% ethanol), if its really that corrosive
BTW, where the hell are you finding 180 proof vodka ?
They don't make such it thing. A few ounces would kill you.
Sounds like that you don't know the difference between "proof" and alcohol content.
Fred
Old Jul 20, 2007 | 04:13 PM
  #42
4bytruckin's Avatar
Originally Posted by Pest
It takes far greater energy to split the whater molecules into Hydrogen and Oxygen. Far more energy than is produced by burning the Hydrogen. So if you have a tank of water, use electricity from the motor runing on Hydrogen, and eventually (or quite quickly) the motor will stop running from lack of fuel. Not enough energy is being generated to split the water anymore.
sad to say your molecular science degree is failing you something awful. the rate of electrolysis on h20 is concurrent with the rate of amprege. let me try to find the formula, but basicly you need a very large surface area running significant amps. also it depends on the electrolite chosen . regular saline solution or brine has a decent separation rate but lets say a potasium chloride solution would potentialy have double the rate due to it's elecrtolitic properties. most people would run regular plates in the tank . alot of very thin plates would increase the amount of surface area. but if you use a mesh or even a a tight metal screening material you can increase the surface area exponentialy. and yes a simple alternator would not produce the necesary amount of hydrogen. but using 3 deep cycle marine batteries in line and a 200 amp or higher welding alternator you can creat and sustain the required voltage. i know it works. it has been done.
Old Jul 20, 2007 | 06:52 PM
  #43
ewong's Avatar
There was a recent artilce in WIRED that gave a 101 on alt fuel issues.
I tend to come from a "follow the money" approch to looking at issues.
In the case of fuels or alternatate fuels...
There seems to be TWO approachs to the issue
a) we need something cheaper
b) we need to protect the environment
While Id like to think we are all concerned with the environment - I think the population in general will only do so up until it slams their wallet.
So - Most people are looking at the COST of the fuel do to the "work" that they need.
Sure, not everyone runs an ROI calculation when buying a car - but Im sure they notice it.
So its not the MPG that matters - it the miles per DOLLAR that matter. Who cares if you get 200 MPG if the actual cost of one gallon of mystery fuel comes out to the same as a 200 gallons of gasoline?
Its not cheaper. So why bother?
At this juncture - the TOTAL life cycle cost of the energy supply - oil is still the cheapest.
By total lifecylce - one has to think of any alternative energy in the same way that Thomas Edison did when thinking about electricity
- how to make it
- how to transport it
- how to store it
- how to sell it
- how to USE it
We have a tremendous infrastructure for making crude oil into gasoline
- wells
- storage
- transport (tankers and pipelines)
- creating it (aka refineries - tho IMHO we dont have enough hence the seasonal "crunches" we see)
- distribution (gas stations)
Some issues with other current alt fuels
-- Alcohol isnt easily transportable via pipelines. It tends to go by rail car. Right now the rail infrastructure and alcohol generation plants arent in place (but people are working on it - see recent issue of Trains)
So - right now there is VERY LITTLE incentive to do alot of research into "alt: fuels" becuase you cant sell the alt fuel for "less" that what a gallon of gas will cost to to the equivalent work.
Now - if gas costs MORE... well then things change.
Thats what the Wired article dicussed - what happens if oil hist $70, $80., $100 a barrel?
First - suddenly areas that dont have oil all of a sudden DO have oil.
The reason they dont have oil is that it cost too much to extract it - if the got it out of the ground it would cost $80 a barrel and well since oil is $60 a barrel - you wouldnt have any buyers...
So - places like CANADA suddenly have ALOT of oil.
And Venezeula too (its why Chavez is making all that noise).
We *could* do what Europe does and tax the hech out of the oil to drive the price up to $5 a gallon. All of a sudden you start seeing
-- alt fuel usage (becuase it becomes CHEAPER than oil)
-- conservation (becuase its cheaper)
-- behavior change (becuase its cheaper)
-- investment (that tax money goes somewhere)
I doubt that will happen in the USA becuase no politician will do it.
Old Jul 21, 2007 | 01:39 PM
  #44
thefallman's Avatar
Originally Posted by FredTJ
Once again I love the fact that people take info as fact.
Well lets just put out the facts and see what happens i dont want to get into a pissing match on this, but you are miss informed on ETHANOL. maybe not E85 i dont have alot of info on that cause i havent researched it. but i do have alot of info on ETHANOL and have friends that race with ETHANOL, so lets just get the Facts out and ill even site them so you can check
Methanol is corrosive, however SO IS ETHANOL.
pH is often used to compare solution acidities. For example, a solution of pH 1 is said to be 10 times as acidic as a solution of pH 2, because the hydrogen ion concentration at pH 1 is ten times the hydrogen ion concentration at pH 2. This is correct as long as the solutions being compared both use the same solvent. You can't use pH to compare the acidities in different solvents because the neutral pH is different for each solvent. For example, the concentration of hydrogen ions in pure ethanol is about 1.58 ? 10-10 M, so ethanol is neutral at pH 9.8. A solution with a pH of 8 would be considered acidic in ethanol, but basic in water!
Quoted from http://antoine.frostburg.edu/chem/se...at-is-pH.shtml
This Qoute again proves that Ethanol in its pure form is not corrosive and is neutral. Highschool Chem taught us that if we werent asleep.
On the other hand Impure Ethanol, ie E85 or Commecially Distilled, is very corrosive.
Total retained biomass (as suspended flocs and entrapped cells) was >50 g/l for medium pH values between 4.0?8.0. The entrapped cells to suspended flocs ratio was highest at pH 4.0, whereas at pH above 5.2 it was close to 1.0. The observed enhancement of cell immobilization on the packing support at low pH seemed to be related to formation of bacterial filaments.
Quoted from http://www.springerlink.com/content/j373ug2444153x78/
Ethanol is much more corrosive than gasoline.
Polyprotic acids
Acids with more than one acidic proton/hydrogen can release all of the protons. Thedescription of these acids ilinked to the multiple number of acidic hydrogen atoms. A diprotoic acid has "two" acidic hydrogens. A triprotic acid has "three" acidic hydrogens. This means H2SO4 has two acidic hydrogens that can be released form each formula unit.
Non-acidic hydrogens
These ideas explain why hydrocarbon compounds like gasoline and butane, C4H10, are not acids even though there are many hydrogen atoms in the molecule. In hydrocarbons, hydrogen atoms are attached to carbon. The C-H bond is nonpolar and strong. Hydrocarbons are not acidic because H is not bonded to an atom in Group 6A or 7A.
Quoted from http://www.800mainstreet.com/acid_ba...oxyacids-.html
This once again says Gasoline itself isnt the corrosive factor its the additives and other ingredients in the gasoline.
That's one of the main problems with ethanol. It can't be transported like normal gasoline through existing networks. Part of it is because it absorbs water and part of it is because it's so corrosive. It has to be transported in stainless containers, which means trucked everywhere.
Is also toxic and pretty easily absorbed through the skin.
It could be transported like normal gasoline if it was 100% pure. And you could keep water out.
As far as being toxic and being absorbed through the skin once again its not the ethanol thats the danger here its the other ingredients. jeeze i mean otherwise we wouldnt have any body living in the hills of TN or KT. Ethanol is not the danger our bodys produce a small amout of Alchol as it is. The danger comes from our bodies inablity to process large quantities of it.
Any you talk about drinking, yes, you better believe it screws you up. Ever have a hangover ? You've just poisoned yourself past what your liver can handle.
See above, and if you read up on this you will find that the major contributor to hangovers is purity of the ethanol. And as said above the quantity and duration of the drinking binge. Your body is perfectly cabable of breaking down and using Ethanol but just not in the quantity. It has nothing to do with the Corrosiveness partly because ETHANOL expecially food grade. Is not corrosive and has a nuetral pH
Info Fromhttp://www.drinkfocus.com/hangovers/causes.php
E85 is a blend of 85% ethanol and 15% gasoline. It does NOTseparate, contrary to your belief.
If the Ethanol has NOO water in it you are correct but think about the problems we already have and continue to have with cheep stations and water in the GAS and Gas doesnt even like water think about how much worse the problems would be with Ethanol Which absolutely LOVES water and will seperate from the gas once it obtains enough water.
There are two main reasons to mix ethanol with gasoline (and more lesser reasons):
1) To make it so you can't drink it, and thus avoid the massive Federal tax that would have to be paid. The ethanol plants produce E95 (95 % ethanol and 5% gasoline) and then additional gasoline is added to make it E85.
Isnt that convient when there are other things to denature it so that we cant drink it??? But we have to use Gasoline so as to add to the potential for it seperating, and thus having a shelf life so once again you cant store it.
2) Ethanol is harder to ignite than gasoline (one of the main reasons that methanol is used in some forms of auto racing) and the addition of gasoline makes it easier to ignite (in the engine) especially for cold starts.
This is just what it appears, an excuse, yes Ethanol is "harder to ignite" the reson for that is its higher octane rating, and higher latent heat. but these both have advantages.
Octane rating with the higher octane rating of Ethanol you can have higher compression engines that burn even more effeciantly and create more power.
Latent Heat, with almost 3 times the Latent Heat of Vaporization of Gasoline Ethanol Cools and increases the Intake charge of an engine thus produces more power per power stroke then gasoline. Notice it doesnt produce more BTU's. you have to use more fuel to get that increase in HP but you can add that fuel now because your intake charge is increased.
Info from http://www.drivingethanol.org/motors...teristics.aspx
The only time that you'll have problems with ethanol mixing with gasoline is when the ethanol isn't, virtually, 100% pure, that is it contains some water.
That's one of the problems with "home production" of ethanol, is getting all the water out of it. You can't distill it pure enough and have to use a compound to absorb the remaining water from it.
And once agian like i said earlier just think about the problems we already have with Water in our gas especially in winter.
Jeez man you really need to go look your ▓▓▓▓ up before you spout off. 2 ounces of 200 proof would be akin to 4 ounces of 100proof i dont think that would kill anyone. and just to prove my point Absolut Vodka and pretty much all Vodkas for that matter are distilled to 180-190 proof
Info From http://absolutad.com/absolut_about/history/made/
There is some debate back and forth on the proof issue evidently according to wikipedia the max proof is 175 that being 100% alcohol but traditionally 100 proof was 50% alcohol.
A "proven" solution was defined as 100 degrees proof (100?). This has since been found to occur at 57.15% ethanol. This is still used as the British definition. A simpler ratio to remember is 7:4, i.e. 70? proof is approximately 40% alcohol by volume. Thus pure alcohol is approximately 175 degrees proof (175?).
http://http://encyclopedia.tfd.com/Proof+(alcohol)
"Proof" means the alcohol content of distilled liquors. It is the percentage of alcohol multiplied by two. For example:
50% alcohol = 100-proof
100% alcohol = 200-proof
http://www.nlm.nih.gov/medlineplus/e...cle/002446.htm
Here is my last link its a guy here in CO that makes stills for fuel production. and sells plans
http://running_on_alcohol.tripod.com/index.html
Old Jul 22, 2007 | 09:02 AM
  #45
Dan.3's Avatar
Fred
THREAD HiJACK!!!
The hangover comes from dehydration. You dont need to drink any alcohol to get a "hangover"
Old Jul 22, 2007 | 10:36 AM
  #46
kpaxfaq's Avatar
Fred
Everclear is 90% abv, and yeah a few shots is all it takes
Old Jul 22, 2007 | 11:57 AM
  #47
dcg9381's Avatar
A larger injector won't help you as the ECU will simply decrease the pulse time to the injector to get the mixture "correct".
It's a very, very simply mod. to the O2 sensor that needs to be done and that's pretty much it.
Fred
A larger injector will help you as the pulse time isn't going to be changed under open loop. You don't use 02 sensor feedback at idle, during warm up, and may not use it under WOT (depending on ECU).
There are going to be limits of what the stock ECU can adjust for in terms of pulse width. As we know we're going to need more fuel and we're likely to hit the limit on that side of the pulse width, why not give it 10% more by default?
Old Jul 22, 2007 | 03:32 PM
  #48
thefallman's Avatar
Fred
Wrong again
The ecu isnt going to adjust the injector pulse width unless it detects a lean or rich mixture. It would adjust the pulse width if it was still using Gasoline. Pure Ethanol uses approximately 30% more fuel then Gas when you have the proper mixture. the plus to this is that pure ethanol produces more power for that 30% more fuel. The exact hp increase is in the range of 20% to 30%. So your mpg goes down but your hp goes up.
So, yes all you have to do is increase the injector size. Your Ecu doesnt know what size your injectors are, or what fuel you are using (other then a flex-fuel vehicle will know what fuel), it only knows what the O2 sensor is telling it, and it will adjust, accordingly within limits, to obtain a proper mixture.
and if you dont believe me just google it
oh and i wouldnt say hijack at all this is all about alt fuels so its on topic
Old Jul 22, 2007 | 06:55 PM
  #49
FredTJ's Avatar
Originally Posted by BAMF_CT2004
THREAD HiJACK!!!
Ahhhhh, some people of this forum "that doesn't give wrong information", simply amaze me...
Hangover is not cause by dehydration.
The toxins in alcohol build up in your body and make you feel sick. A chief culprit is a chemical called acetaldehyde. This is an alcohol by-product that research suggests may cause the worst of your hangover symptoms.
Congeners are another cause of hangovers. These are impurities created during the fermentation process in some types of alcohol. Low quality wines and many dark liquors tend to have high levels of congeners.
http://ask.yahoo.com/20020805.html
he chief cause of hangover is acute withdrawal from alcohol,? says Mack Mitchell, M.D., vice president of the Alcoholic Beverage Medical Research Foundation in Baltimore, and assistant professor of medicine at Johns Hopkins University. ?The cells in your brain physically change in response to the alcohol?s presence; when the alcohol is gone, you go through withdrawal until those cells get used to doing without the alcohol.? Couple that with the effects alcohol has on the blood vessels in your head (they can swell significantly), and you end up living through a day after that you?d rather forget.
http://www.beekmanwine.com/prevtopas.htm
When you drink alcohol, you take poison into your body. Having a hangover after drinking is nothing more than the after-effects of poisoning. Alcohol poisons people in two ways ? physically and psychologically. The physical effects include the familiar headaches, vomiting and nausea.
http://www.irishhealth.com/index.html?level=4&con=294
caused by a condition known as metabolic acidosis. Acidosis is when your blood becomes more acidic than it should be. There are a number of reasons why alcohol causes this, but suffice it to say that alcohol interferes with the normal metabolism of some acids, and actually produces others. The end result is a slight increase in the acidity of your blood. This increase reaches its peak during the hangover period, and the level of acidity is strongly correlated with the severity of the hangover symptoms. It takes your kidneys and lungs about 18-24 hours to return the blood acid levels back to normal. It seems likely that the symptoms of nausea and sweating are related to this temporary increase in blood acidity.
http://www.madsci.org/posts/archives...6552.Me.r.html
hangover are the products from the breakdown of ethanol via liver enzymes. Ethanol is converted to acetaldehyde by the enzyme alcohol dehydrogenase, and then from acetaldehyde to acetic acid by the enzyme acetaldehyde dehydrogenase. Acetaldehyde (ethanal) is mildly toxic, contributing to the hangover. These two reactions also require the conversion of NAD+ to NADH. With an excess of NADH, the lactate dehydrogenase reaction is driven to produce lactate from pyruvate (the end product of glycolysis) in order to regenerate NAD+ and sustain life. This diverts pyruvate from other pathways such as gluconeogenesis, thereby impairing the ability of the liver to supply glucose to tissues, especially the brain. Because glucose is the primary energy source of the brain, this lack of glucose contributes to hangover symptoms such as fatigue, weakness, mood disturbances, and decreased attention and concentration.
There are various nervous system effects: the removal of the depressive effects of alcohol in the brain probably account for the light and noise sensitivity.
In addition, it is thought that the presence of other alcohols (such as fusel oils), by-products of the alcoholic fermentation also called congeners, exaggerate many of the symptoms (cogeners may also be zinc or other metals added primarily to sweet liqueurs to enhance their flavor); this probably accounts for the mitigation of the effects when distilled alcohol, particularly vodka, is consumed instead.
The amount of congeners in the drink may also have an effect. Red wines have more congeners than white wines, and some people note less of a hangover with white wine. Some individuals have a strong negative reaction to red wine called Red Wine Headache that can affect them within 15 minutes after drinking a single glass of red wine. The headache is usually accompanied by nausea and flushing.
In alcohol metabolism, one molecule of ethanol (the primary active ingredient in alcoholic beverages) produces 2 molecules of NADH, utilizing Vitamin B12 as a coenzyme. Over-consumption of ethanol may cause vitamin B12 deficiency as well.
And it goes on and on and on.
Certainly dehydration doesn't help the matter, but it's not the cause of a hangover. Having seen people suffering from dehydration I and they can tell you that it isn't the same.
Fred
Old Jul 22, 2007 | 07:51 PM
  #50
FredTJ's Avatar
Since we don't run much, or often in open loop mode, idle and WOT, those states are kinda not really relevant as we spend most of our time, or at least I do, not in one of those conditions.
When we're running normally in close loop the ECU does use O2 sensor and uses it to adjust the pulse width to the injectors.
Just to put things in total perspective here.
I'm 58 years old and am an engineer.I work for a division of Pacific Scientific that's owned by Danaher. You can check out some of the stuff that we do on the web.
I, with a couple of other engineers at work, started working on an E85 solution for late model vehicles that aren't already "flex fuel" at the beginning of last year when I still had my Jeep. I was going to do a total conversion on it, though there isn't really much that needs to be done.
Most/all late model vehicles will run on E85, just not as efficiently as they should due to the fuel mixture problem. The ECU is set to try and maintain a ca 14.7:1 ratio.
Several companies sell a device (electronic) that hooks into the wiring harness of the injectors and increase the pulse width ca 30%+- from whatever the ECU is currently pulsing.
The problem with those is that the ECU will, often, still try to adjust the pulse width, based off the O2 sensor readings, again, depending on speed, etc.
I came up with a little device that works at the other end, instead of at the injector end and is really inexpensive to do.
We looked at a handful of vehicles and scoped the pulse width under various conditions and various changes.
I can tell you with 100% certainly, that the ECU will adjust the pulse width if you add bigger injectors, the best that it can.
The solution isn't messing with the injector end, but "messing" with the other
thing(s) that control the amount of fuel injected.
A simply device can turn most any late model (and that reason for "late model" is that it must be EFI'ed and it must have ethanol resistant parts {contrary to what some thing, ethanol is corrosive to some parts that are in older vehicles fuel delivery systems} already in the fuel delivery system. Anything from the early/mid 90's on will work fine), into a "flex fuel" vehicle that will run either E85 or regular gasoline with the flip of a switch, and when I say "run" E85, I mean consume it "correctly".
The reason that the ECU will attempt to adjust the pulse width is because the a/f ratio of gasoline is a lot different than that of ethanol (E85, etc.).
The O2 sensor does detect the a/f ratio correctly, even if running relatively straight ethanol. The problem is that the O2 content isn't correct when running ethanol for gasoline (which the ECU believes you are running), so it attempts to correct it (the a/f ratio).
Put another way the stoichiometric value between gasoline and ethanol is a lot different and because of that the O2 sensor reading(s) will not be even close to correct when running E85 (or even straight ethanol), and the ECU will attempt to adjust the pulse width of the injectors, the only thing it can really do to get the a/f ratio where it thinks it should be, to the "correct" value.
Now, you may ask what about LPG and CNG. Those work pretty much ok "right out of the box" because the stoichiometric ratio for both of those is just about the same as gasoline.
There are a lot of problems with E85, outside of the actual burning of it in vehicles.
Currently here in the US, corn is the stock base for it and that's no where close to practical. Nice move for our current administration to appease the populace of Idaho, etc.
Corn won't work. We can't produce anywhere near enough. We've increased production of corn and it's costing the economy a lot right now. The increase in land for corn planting has taken away land for other food stocks, which is driving up the prices of a lot of items in the grocery store, not just corn.
The price of fertilizer has gone way up, which, again, effects a ton of other things.
There is no infrastructure in place to transport ethanol. Stainless has to be used in many applications and, as such, the cost of stainless is heading through the roof.
Look at some of the companies involved in ethanol production across several different sectors and it's easy to see what's happening.
If you look at the fertilizer companies (TNH, MOS, POT, MON, SQM, to name a few) and see what their stocks have done the last year.
Look at the corn futures and see what they're doing.
Look at the companies that produce stainless, ATI for example and see what their stocks have done.
Now, look at the companies that produce ethanol and see what their stocks have done (gone down).
Anyway, I'm done with this whole discussion.
It's too obvious that there are simply too many wanne be rocket scientist here with no real (apparent) experience with what's being discussed.
Y'all have fun with it.
Fred
Old Jul 23, 2007 | 11:24 AM
  #51
4bytruckin's Avatar
like don imus, i must appologize for this quagmire that has insued. the amount of bs that has been thrown rest surely upon the shoulders of those that threw it. once again, i'm sorry
Old Jul 23, 2007 | 02:13 PM
  #52
dcg9381's Avatar
You've done some work in this area, so lets keep the discussion going. It's good to remove disinformation:
Trust me, your HP isn't going to go up on E85 without adjusting other engine dynamics. If you think it will, let's do a little dyno based wager.. :-)
I've seen piggy backs also, they typically haven't worked very well with the early generation of toyota EFI systems. In theory, this would work better than larger injectors as you could adjust when to turn on the additional pulse width.
Pulse width resolution at idle can be very sensitive.. Adding 20% more fuel at idle could result in a vehicle that doesn't run very well (or pass emissions).
Again - armchair theory here...
I agree that you've got to design an ECU that deals with the alternate fuel, but if these guys are talking about hacking together some sort of system that would be drivable, they could try slightly larger injectors.. Again, this is a band-aid, and totally unnecessary if the stock ECU is allowed enough range to bring the mixture back to stoichiometric.
I was baffled for a while when people indicated that E85 was working in non-flex vehicles, but then I discovered that the narrowband 02 drives the mixture toward stoichiometric - not necessarily a specific air fuel ratio... It made a lot more sense at that time.
I still don't believe people are getting more power out of E85 without alternate tuning or engine modificiations.
[/quote]
So I'm very curious here... What do you know about first generation toyota vehicles and hardware compliance with Ethanol? Injectors have rubbers seals, but are we talking about additional wear or failure with a short period of time... We've got steel tanks - not stainless, but how big an issue is this in reality?
Note, I came darn close to filling up with E85 this weekend. Premium was hovering at about $3.14/gal. E85 @ $2.50. I didn't simply because I didn't want to have to mess with tuning bugs on the way home (250 miles). I was prepared to adjust my idle and set my target AFRs on the wideband to appropriate E85 levels.
I'm probably going to try in locally, but start with E85 / gas mixtures.
I understand it's more corrosive, but I don't think that's an immediate concern.
For a turbo motor, the high octane levels have obvious advantages. Another advantage is that running more fuel will also cool my EGT temps - I'm hitting 1400 degrees under boost cruise, which is pretty darn hot.
Quasi-educated discussion encouraged.
Old Jul 23, 2007 | 06:30 PM
  #53
thefallman's Avatar
The proble with filling up with E85 is that your going to get less mpg with it so in reality your going to be paying the same if not more per mile for fuel unelss you can get E85 for cheaper then that with the qouted price of gasoline.
another thing about this because of the specific heat of ethanol it cools the charge and chamber more so runs cooler already without running more fuel or rich
On another subject
the whole debate with Fred TJ
I'm going to let it die here as well. I think most of our disagreement and conflict comes from my talking about burning 100% pure ethanol. And Freds talking about E85 and or impure Ethanol.
I also misspoke earlier when i said all you need is bigger injectors. You all so should use a Air Fuel controller to tune your engine correctly
I will make one last comment about my contention that part of the reason for adding gas is to create an artifical shelf life.
Ask some of your grandparents whether gasoline back in the day would go bad. ill tell you that ive talked to alot of people. farmers, ranchers, and so many others, The point is that giving a fuel a shelf life increases your profit margin, Because now people cannot store fuel and stock up when its cheap and use it when its expensive. Instead they have to buy it from the distributor every tank fill. And when that happens the distributor can change the price at any point. This would be less likely if more people had there own reserves because the companies would know that they were unlikely to make much mone because people would use reserves till the price came down. this would reduce the constant price changes.
anyway thats enough of my rant now
feel free to flame
Old Jul 26, 2007 | 11:03 PM
  #54
netgodsrdn2's Avatar
anyone else see this site?
http://www.change2e85.com
I don't really know enough to even begin to argue about the technical details.
But I'd love to convert to E85 and add a turbo to my 22RE.
Ron
80Truck
Oct 12, 2025 07:25 PM
redneck17
Oct 29, 2015 09:09 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
Sep 4, 2015 09:27 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
