Aisin manual hub swap questions
Old Apr 10, 2009 | 01:54 PM
Bobzombie's Avatar
I am installing my aisin locking hubs tomorrow and just want to be sure It goes smooth.
I have read other threads and done the searches and it seams that it is as simple as unbolting the add hubs and bolting on the manual hubs.
Any other recomendations??
Last edited by waskillywabbit; Apr 10, 2009 at 02:43 PM. Reason: Title clarity per posted sticky
Old Apr 10, 2009 | 02:36 PM
iamsuperbleeder's Avatar
check your wheels bearing while you're in there; it may not hurt to repack them while you've got the hubs out of the way
other than that, if you've got the hub mounting gaskets, then you're set
Old Apr 10, 2009 | 02:40 PM
waskillywabbit's Avatar
ADD is swap out and add new gaskets.
Auto is adding wheel bearing nuts to replace the auto junk.
PS In the future please name your threads relevant to the subject as I had to edit this one. There is a sticky about naming threads.
Old Apr 10, 2009 | 02:42 PM
ah yes, good point; are you getting rid of autos or ADD's?
and yeah, I'm guilty of thread title's too; you know this all to well Wabbit
EDIT, never mind, you said "unbolting the add hubs", so I will assume you're coming from ADD
Old Apr 10, 2009 | 02:56 PM
toyota4x4907's Avatar
Auto-hubs were only used for a few years in the late '80s
Looks like '84-'88 for trucks and '84-'89 for 4runners!
Old Apr 10, 2009 | 03:16 PM
24Runna's Avatar
Whats the part numbers on those gaskets, anyone know?
Old Apr 10, 2009 | 03:26 PM
Bobzombie's Avatar
Sorry about the title I should have been more to the point.
My 90 has ADD
The gaskets from the ADD hubs wont work?? I know they are round butbolt pattern is still the same so what if some gasket hangs out.?
Old Apr 10, 2009 | 04:21 PM
I got more than a part number, I've got a picture
they're the larger round ones on the right, Toyota part number 43422-60010, and you will need 2, one for each side
the other gaskets pictured are for the hub cover, and the O-ring for the dial
Old Apr 10, 2009 | 04:44 PM
24Runna's Avatar
iamsuperbleeder, I award One (1) Internet, good for use on the internet. Or my expressive gratitude, whichever. lol.
Old Apr 10, 2009 | 05:09 PM
My 90 has ADD
Making concise titles helps future users and others know what you are asking so you get answers more quickly.
Yep, manual hub gaskets are all the same for the Aisins, every year every type axle on the Toyotas. None of the gasket should hang out.
Old Apr 10, 2009 | 05:10 PM
alright, I can open a savings account now!
no problem man
Old Apr 10, 2009 | 05:13 PM
Bobzombie's Avatar
Unfortunatle I am not at work or I would have just looked it up but thanks for your help !!
WOOHOO manual hubs tomorrow!!
edit: by the way I got them for 35 dollars !! And the techs at work took them apart for me for free. Got to love working at the dealer!!
Old Apr 11, 2009 | 01:02 PM
99SR5's Avatar
so if one is doing auto hubs, you need new nuts on the hubs? where could i find them? what exactly would i need?
Old Apr 11, 2009 | 01:10 PM
HOLY CRAP, you got the pair of them for $35!
damn, that's a deal there!
how did you manage that?
Also, one of the good things about the factory Aisins is that there's really nothing inside them that'll break from normal usage. Most of the problems people have with them accur when rebuilding them; people seem to either loose the little ball on the dial, or don't clock the cover right when they re-install it making the hubs not unlock.
Old Apr 11, 2009 | 02:45 PM
I think you are confused.
This thread is about replacing auto or ADD hubs with Aisin manual hubs.
Auto hubs suck.
Old Apr 11, 2009 | 03:15 PM
Tubbyfatty's Avatar
Auto hubs suck.
Hey, i like mine, im lazy and i dont have to get out to throw it in 4wd, but i hate how they unlock in reverse.
Old Apr 11, 2009 | 03:17 PM
lmao, I was just thinking while reading the first half of that, I bet you never try reverse in 4wd then
I hate having to get out to lock mine in, but I like the reliablity and durability, not to mention the easy of maintanence of manuals
Old Apr 11, 2009 | 03:21 PM
Tubbyfatty's Avatar
Theres maintance with auto hubs?
Old Apr 11, 2009 | 03:46 PM
Justinlhc's Avatar
Not any more or less than manual hubs AFAIK.
I put manual hubs on my 4Runner because I don't want my crappy CV's turning when they don't need to be. It also gives me the option of 2lo if I want it for whatever strange reason.
If I had a locker in the front it would give me the option of unlocking one side only for certain situations that might require it.
Old Apr 11, 2009 | 04:07 PM
You have a 94 4Runner with auto hubs?
AFAIK...
Auto hubs can be found on trucks from 1984-1988, and on 4Runners from 1984-1989.
ADD (automatic differential disconnect) was used in both trucks (1989-current) and 4Runners (1990-current).
