Air shocks in front?
Old Oct 3, 2012 | 03:11 PM
fletcher0780's Avatar
I've got a 92 4x4 single cab 22re that I'm mounting a plow to. On my last plow truck (Jeep TJ) I used air bags inside the front springs that I could inflate and help carry the plow, but not effect regular driving. Does anyone know of replacement front air shocks, that I could add pressure to when the plow is mounted and lower when it is off? I know timbrens are an option too, but $200+ for bump stops seems extreme.
Old Oct 3, 2012 | 03:18 PM
snobdds's Avatar
On that year of truck, there is a torsion bar spring, not a coil spring like on the heaps. There would be no way to use a bag of any type.
Best bet would be to get a bigger torsion bar from OME, Sway-A-Way, etc.
This will allow you run that plow...
Old Oct 3, 2012 | 03:26 PM
I know there are torsion bars and not springs I just wanted to know if there is an air shock I can replace the front shocks with to add more suspension when I need it. I don't want to add larger torsion bars and create a stiffer ride when plow is off.
Thanks.
Old Oct 3, 2012 | 04:52 PM
Yodaforce's Avatar
It's one of those cases where you cannot just buy an air shock for that truck, but instead, walk into an autoparts store and ask to see every different air shock they have (usually only a few diff ones) and compare it to the mounts and general dimensions of the factory shock. Find something that could be easily installed with minimal fabrication or modification.
The closest thing I remember doing something similar was back in the 80's when people were using air shocks on their minis to raise and lower them, and even though they were 2wd, there were companies that sold them as kits with misc brackets and such to get them to work.
Sounds like a good idea to me.
Old Oct 3, 2012 | 05:27 PM
Thanks for the advice. I was being lazy and hoped someone else already did the leg work. I'll have to find the specs for the stock shocks and hit up the parts stores or look online for something that will work.
nanhodges2733
May 29, 2020 03:28 PM
coryc85
Sep 9, 2015 06:24 AM
sojourner567
Jul 16, 2015 08:52 PM
akaphilly
Jul 9, 2015 02:34 PM
skoti89
Jul 8, 2015 12:05 AM
