air regulator, arb locker question?
Old Jun 5, 2007 | 06:01 PM
fthertime666's Avatar
Recently I installed a siege engineering oba setup on my truck, and a rear ARB locker. The siege engineering tank and pressure switch are setup to run at 150-180 psi. The ARB locker needs between 85-105 psi to operate, too much pressure may damage the ARB and void any warranty. So.... I need a regulator to control the pressure. My question is, where can I find a suitable air regulator and what have other people used? From my initial experiments a in-line regulator such as one used for an impact wrench would not be suitable as it only controls pressure at flow and does not control static pressure. Or am I missing something?
Old Jun 7, 2007 | 06:46 PM
bueller, bueller, anyone...?
Ok, my main reason for posting was to see if anyone had a solution that was "off the shelf" like from Home Depot or the like. Talked to a guy from a welding supply shop and he is pretty confident that he can get something that will work... just don't want to wait a week for the part to come in.
Old Jun 7, 2007 | 06:47 PM
Damn, what a loser! Who responds to their own thread?
Old Jun 7, 2007 | 06:54 PM
L33T35T 4Runner's Avatar
I bought a regulator at lowes. you can get them with or without an air/water separator. I would recommend you get one with.
even though it has no filter, one like this will work. drop by your nearest lowes or home depot and you'll find em.
lowes
http://www.lowes.com/lowes/lkn?actio...0AV&lpage=none
home depot
http://www.homedepot.com/webapp/wcs/...ctId=100019273
I use one similar to that one for my air horns. my system pressure is normally around 110 but i run my horns at 60-80 psi
Old Jun 8, 2007 | 04:53 AM
tried that, doesn't control STATIC pressure, just pressure at flow.
Old Jun 8, 2007 | 05:24 AM
Ceedub's Avatar
The only static pressure reg's I work with are wall mounted for shop air here in the maint. bay. Can't recall seeing portable ones, although I'm sure they make 'em good luck!
Old Jun 8, 2007 | 06:09 AM
GV27's Avatar
Well, I would guess you know more about these things than I do.....but perhaps you're over-thinking this?
All I know is from my experience with my own compressor at home. My compressor is setup with a pressure cutoff switch that's measuring the pressure in the tank. It also has a pressure gauge on the tank. Then it has a regulator like the ones linked above, I believe, for the output.
Now, let's take for example, filling up the tires on my mountain bike. I turn on the compressor and it fills to 120psi. Then I set the regulator for 40psi. Now if I fill up my tires to the point where no more air is flowing from the compressor into the tire I have 40psi in the tire and not 120psi - it'd probably explode if I put 120psi in it! Why wouldn't the same thing happen with the air-locker?
C
Old Jun 10, 2007 | 05:25 PM
Ok, moral of the story is don't be cheap. Went back to Lowes and bought a self-releiving type regulator and... it works great. Finally had everything working with no leaks. Went to the local mudhole, didn't even need to lock the front hubs. Whoo-hoo!!!
Old Jun 10, 2007 | 05:36 PM
and some new runnin' shoes
Jun 1, 2021 01:51 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
hamburg99
Jul 13, 2015 09:54 PM
A2theK
Jul 12, 2015 10:46 AM
