add relay/fuel pump relay
Old Jan 19, 2006 | 07:41 PM
helopilot's Avatar
Hi all
I have been trouble shooting the add system. I am searching for the relay. I found a relay under the dash passenger side of the column. This is where everyone says the ADD relay is. The relay I found says Fuel Pump Relay. With the relay removed car runs fine. Could someone have put it there instead. I searched and found the fuel pump relay is supposed to be behind the glove box. My 90 has a/c and I don't see any room for or any relays there. The relay I am speaking of is mounted on a bracket at the brake pedal.
My 4-runner is a 90 model v-6 5 speed.
Thanks for the any help
Old Jan 20, 2006 | 07:46 AM
eric-the-red's Avatar
The ADD relay is to the right of the steering column, kind of behind the ignition switch, so that one you found is probably it. It should have 5 wires going to it. 4runner's don't have anything called a fuel pump relay, it's controlled by the circuit opening relay, which is behind the glove box. Could be someone used a fuel pump relay from another vehicle in place of the ADD relay.
Old Jan 20, 2006 | 07:09 PM
helopilot's Avatar
I solved the idenity problem. I went and saw my handy Toyota Parts guy today. He pulled out a relay for the ADD. I asked if it went near the brake pedal. He went to pull up a diagram and while he was away I started looking at the relay. It said "fuel pump relay" right on it. The parts guy said they use some of the same relays for different things. Tomorrow I will take mine down and we can check the both with the ohm meter.
Old Jan 22, 2006 | 06:32 AM
helopilot's Avatar
Add problem solved. I took my relay to the dealer to test mine and his. They tested the same. (saved $77.00) He let me sit down with the factory manual for a bit. This guy went as far as to copy 6 pages of ADD trouble shooting guides and schematics for me. Brought it all home nd started testing. Turns out the wire going into the indicator switch conector had pulled loose. Tested and we have 4WD now.. Got to go back and thank the guy Monday.
Old Aug 25, 2006 | 01:46 PM
Buddy's Avatar
Originally Posted by helopilot
Hi all
thanks for this thread finally found the damn thing.
Doug4320
Mar 24, 2018 10:11 PM
dumpster84
Apr 30, 2016 06:03 AM
Hiluxtrucha
Jul 22, 2015 10:00 AM
jackiebrownia
Jul 20, 2015 09:02 AM
colinmil
Jul 6, 2015 04:03 PM
