ADD front diff tube and seals
Old May 24, 2020 | 07:20 PM
hatowner's Avatar
Been searching the series of tubes with no avail. I can't figure out how to get the front diff. tube apart. Is there a seal in there? Is it worth replacing while all this is apart?
the seal for the tube side/driver side appears to be a gasket on the tube bracket.
the only seal i can locate is on the passenger side (short side).
whole tube with snap ring and adjustable gear removed.
Tube side with needle bearing spindle. Does this come out like the passenger short side?
Old May 24, 2020 | 09:19 PM
N_Aviles's Avatar
Yes the axle stub pops out. There is a seal behind there.
Seal goes in the empty spot
Old May 25, 2020 | 04:09 PM
hatowner's Avatar
any idea what the part number would be? How about the tube, should I just leave it alone and put it back on. Thanks so much.
Old May 25, 2020 | 04:38 PM
hatowner's Avatar
No seal present here, freshly popped the spline stem
Old May 31, 2020 | 07:23 PM
hatowner's Avatar
Spoiler
I see the other diff. in the background. Is that a non-add diff? If not would there be a reason there isn't a seal present? Thanks
Old May 31, 2020 | 09:38 PM
hatowner's Avatar
Answer from gearinstalls
No seal on tube side says http://www.gearinstalls.com/rickdiaz.htm
Old May 31, 2020 | 09:50 PM
millball's Avatar
There IS a seal there in the housing on a diff equipped with Non-ADD Plain tube.
The seal on the ADD tube is in the tube itself.
Old Jun 18, 2020 | 02:16 PM
hatowner's Avatar
ADD tube seal removed.
I removed the seal with a seal pry and it appears everything is pressed in. Unless anyone has a suggestion, im just throwing the new seal and just ignore whatever is inside that tube. I would lile to one day service whatever is im there. Thanks for all the help, learning a lot over here.
skoti89
Jul 17, 2023 08:02 AM
shepsyota
Nov 12, 2014 01:59 PM
saitotiktmdog
Sep 9, 2008 06:55 AM
904wdPickup
Feb 11, 2004 10:36 PM
