AAL install help
Old Jun 10, 2006 | 03:53 PM
geoduke's Avatar
AAL install help
I am installing the Rancho AAL system on my 88 runner and have run into a problem.
There are a couple of spring clips (leaf alignment clamps?) that are attached to the leafs with rivets. I need to remove these clips in order to get the new leafs in the correct order (descending length going downward). The kit supplied me with new clips but I want to make sure it's OK to cut these off because one of them has a pad on the top of it that looks like it will hit the frame in extreme situations. You can see the pad I'm talking about in Toddski's writeup in his second pic on the right hand side of the spring. Is it OK to take this off?
https://www.yotatech.com/forums/show...ght=add-a-leaf
If anyone has removed these in the past, what is the easiest way to get them off? Grind the head off or chisel it off? Thanks for the help, I'll post before and after pics when I get this done (hopefully soon).
Old Jun 10, 2006 | 04:39 PM
87rustbucket's Avatar
My pads fell off years ago and it hasnt been a prob. Just use a grinder or a sawsall to get the old ones off.
nvdesertrunner
May 11, 2020 08:18 PM
wwjr
Sep 7, 2015 09:27 AM
punks_is_4x4
Aug 21, 2015 01:35 PM
Esibnitsud
Jul 30, 2015 08:19 PM
