A340H help
Old Mar 24, 2006 | 11:11 AM
kt19's Avatar
Originally Posted by cmscott16
Your problems are the direct result of a freewheeling overrunning clutch in your torque converter. Basically, you no longer have the use of your stator, which sits inbetween your impeller and turbine and provides for torque multiplication in your torque converter. The stator redirects fluid in order to multiply torque during acceleration. It rotates on an overruning clutch that holds the stator stationary during acceleration. If this clutch fails, or your stator breaks, then you will have no acceleration until stall speeds or your lockup comes on. It is not repairable and you will need to purchase a new torque converter.
I hope many read this.
Old Mar 24, 2006 | 12:20 PM
snap-on's Avatar
thats the best info ive seen on a torque converter problems yet.
I did eventually discover that my hisitation/lag/lac of acceleration was due to timming issues as a result of the bottom timing crank gear wearing out the drift key from lack of proper torque from the crankbolt.
see "lesson learned" https://www.yotatech.com/forums/f116/lesson-learned-pics-76293/
At this point i have no reason to think there is anything wrong with the trans. Once i get the motor back in (from the rebuild) we will see!
Old Dec 9, 2009 | 09:22 PM
jakebo's Avatar
4runner
so ya i have a 1994 4runner that i just got.
when i went on the free way for the first time i was reving at 4000 rpm. i think it was because overdrice was off. but i dont know has this ever happened to you
Old Feb 24, 2011 | 12:50 PM
LGcrawler's Avatar
HAHA i remember that 17 to 85 high revin like a mofo
Hugh_Mann
Aug 31, 2015 04:02 AM
Guardian_Saint
Jul 30, 2007 08:41 PM
bb80sc
Apr 12, 2006 06:09 AM
AaronW
Nov 9, 2005 05:27 PM
Cebby
Jul 26, 2005 08:37 PM
